Boyle's Law, does it hold true in a non finite container ?
In summary, the Le Chatelier principle does not hold for gases because they are not contained and Boyle's law does not apply.
karen_lorr
63
If a gas will expand to fill the available space (container) does this still hold true if the "container" is the atmosphere?
Assuming the gas(es) can escape (either in molecular or in subs - atoms) from the area around the Earth containing our atmosphere this means that the gas is not contained so Bolye's law is not applicaable as the this makes the contain non-finite (not contained).
If this is the case (non-finite area) ?? then does Boyle's law hold for, for example water evaporation, where it could (although not likely) escape the system.
Thank you
Good morning Karen.
No, Boyle's law does not apply to the atmosphere.
But that is not because of its size.
Boyles law states that PV = a constant.
In order to apply this you have to have one pressure (and one volume) to represent the whole mass of gas.
The pressure in the atmosphere is not constant - it varies generally with altitude and also from place to place.
This is because there is another agent acting, that is not included in Boyles law. That is gravity.
In fact Boyles law excludes anybody force, of which gravity is an example.
You can, however, apply the law locally to a small enough volume to discount the effect of gravity.
Can you think of any other body forces?
If Bolye's is not applicable due to the PV <> a constant
then (just wondering here)
is the same true of the Le Chatelier principle (basically a gas will expand to fill the space) - if the space is non-finite or (as you point out) there are other forces involved
If we assume a given volume of H2O the Le Chatelier principle will take too long to achieve anyway - as the H2O isn't "up there" long enough away, so it would never occur -, but is the general principle still valid - the water will spread out (assuming nothing else, eg, gravity, wind, etc) until it was evenly distributed over the entire space (to relieve the pressure in the volume)
Related to Boyle's Law, does it hold true in a non finite container ?
1. What is Boyle's Law?
Boyle's Law is a gas law that states the volume of a gas is inversely proportional to its pressure, assuming temperature and amount of gas remain constant.
2. What is a non finite container?
A non finite container refers to a container that does not have a definite or fixed size or volume. This could include an open container or a container with flexible walls.
3. Does Boyle's Law apply to non finite containers?
Yes, Boyle's Law still holds true in a non finite container as long as the temperature and amount of gas remain constant. The relationship between volume and pressure will still follow the inverse proportion.
4. Can Boyle's Law be applied to both gases and liquids?
Yes, Boyle's Law can be applied to both gases and liquids as long as the temperature and amount of substance remain constant.
5. How is Boyle's Law related to the ideal gas law?
Boyle's Law is one of the gas laws that is incorporated into the ideal gas law. The ideal gas law combines Boyle's Law, Charles's Law, and Avogadro's Law to describe the behavior of an ideal gas. The ideal gas law equation is PV = nRT, where P is pressure, V is volume, n is the number of moles of gas, R is the gas constant, and T is the temperature in Kelvin.
