BPSK singlepath Rayleigh channel
In summary, the conversation discusses the aim of deriving and simulating the error rate performance of binary PSK when transmitted over a single-path slowly fading channel. The frequency-nonselective channel results in multiplicative distortion and the received signal can be processed using a matched filter for ideal coherent detection. The error rate of binary PSK can be expressed as a function of the received SNR, and the steps to compute it are suggested, including taking the convolution of the received signal with a matched filter and considering the possible output signal values. The pdf of the output noise must also be obtained before computing the error probability.
yongs90
The aim of this exercise is to derive and simulate the error rate performance
of binary PSK when the signal is transmitted over a single-path (or frequency
non-selective) slowly fading channel. The frequency-nonselective channel results
in multiplicative distortion of the transmitted signal s(t). In addition, the con-
dition that the channel fades slowly implies that the multiplicative process may
be regarded as a constant during at least one signaling interval. Therefore, the
received equivalent lowpass signal in one signaling interval is
r(t) = [itex]\alpha[/itex] * exp(j * [itex]\phi[/itex]) * s(t) + z(t) 0 [itex]\leq[/itex] t [itex]\leq[/itex] ts
where z(t) represents the complex-valued white Gaussian noise process with
power spectral density [itex]N_0[/itex]/2
Assume that the channel fading is sufficiently slow that the phase shift, [itex]\phi[/itex] can
be estimated from the received signal without error. Then, we can achieve ideal
coherent detection of the received signal. The received signal can be processed
by passing it through a matched filter. Show that for a fixed (time-invariant)
channel, i.e., for a fixed attenuation [itex]\alpha[/itex], the error rate of binary PSK as a function
of the received SNR, [itex]\gamma[/itex] is
[itex]P_b[/itex]([itex]\gamma[/itex]) = Q([itex]\sqrt{}2\gamma[/itex])
where [itex]\gamma[/itex] = [itex]\alpha^2 E_b / N_0[/itex] and [itex]E_b[/itex] is the energy of the transmitted signal per bit.
Can someone give me an idea on how to start..
How do I go about it
i) Take the convolution of r(t) with the impulse response of a filter matched to s(t). Consider output signal and output noise separately.
ii) Remember that the modulation method is binary PSK, which means the phase shift is either 0 or pi. What is the possible output signal values?
iii) Before you compute error probability, you must obtain the pdf of the output noise.
FAQ: BPSK singlepath Rayleigh channel
1. What is BPSK singlepath Rayleigh channel?
BPSK (Binary Phase Shift Keying) singlepath Rayleigh channel is a communication channel used in digital communication systems. It is a type of wireless channel that is modeled after the Rayleigh fading channel, which is a common model for wireless communication channels. In this channel, the transmitted signal is modulated using BPSK, which is a type of digital modulation that uses two different phases to represent binary data. The channel is called "singlepath" because it only has one propagation path between the transmitter and receiver.
2. What is the significance of using BPSK in a Rayleigh channel?
BPSK is often used in Rayleigh channels because it is a type of modulation that is relatively immune to the effects of fading, which is a common phenomenon in wireless channels. In Rayleigh channels, the signal can experience fading due to multipath propagation, where the signal takes different paths between the transmitter and receiver, resulting in variations in signal strength. BPSK is able to mitigate the effects of fading by using two different phases to represent binary data, making it more robust compared to other modulation schemes.
3. How does a BPSK singlepath Rayleigh channel work?
In a BPSK singlepath Rayleigh channel, the transmitted signal is modulated using BPSK, where the information is represented by changing the phase of the transmitted signal. The modulated signal is then transmitted through the channel, where it experiences fading due to multipath propagation. At the receiver, the signal is demodulated using BPSK, and the received data is compared with the transmitted data to determine the presence of errors. This process is repeated for each transmitted symbol to ensure reliable communication.
4. What are the advantages of using a BPSK singlepath Rayleigh channel?
One of the main advantages of using a BPSK singlepath Rayleigh channel is its robustness against fading. BPSK is able to mitigate the effects of fading and maintain reliable communication even in challenging channel conditions. Additionally, BPSK is a simple and efficient modulation scheme, making it easier to implement in digital communication systems. It is also less complex to demodulate compared to other modulation schemes, making it suitable for real-time applications.
5. What are the applications of BPSK singlepath Rayleigh channel?
BPSK singlepath Rayleigh channel is commonly used in wireless communication systems, such as cellular networks and satellite communication. It is also used in digital broadcasting, such as digital television and radio, as well as in wireless sensor networks and internet of things (IoT) devices. BPSK singlepath Rayleigh channel is also used in military and defense applications, where reliable communication is crucial.
9K
21K
