Bra ket notation for magnitude of two vectors
In summary, the homework equation a = linear combinations of a(ij)mρ2(|f⟩,|fn|)Fourier expansion of |f| in terms of Fourier basis vectors |em| is ρ2(|f|,|fn|)={⟨f|f⟩-∑|⟨em|f⟩|2+∑|amn-|⟨em|f⟩|2}.
Vitani11
275
If I had two vectors say ⟨em|f⟩⟨f|em⟩ does this equal |⟨em|f⟩|2? e is a basis and f is some arbitrary function. I ask this because I have a problem which is to show the following: Show that for the Fourier expansion of |f⟩ in terms of Fourier basis vectors |em⟩ is ρ2(|f⟩,|fn⟩) = {⟨f|f⟩-∑|⟨em|f⟩|2+∑|amn-|⟨em|f⟩|2.
ρ2(|f⟩,|fn⟩) Fourier expansion of |f⟩ in terms of Fourier basis vectors |em
f is some function
fn is the nth function
All summations are from m=-n to n
Here is what I have done:
ρ2(|f⟩,|fn⟩)=(⟨f|-⟨fn|)(|f⟩-|fn⟩)
=⟨f|f⟩-⟨f|fn⟩-⟨fn|f⟩+⟨fn|fn
= ⟨f|f⟩-⟨f|∑amn|em⟩-⟨fn|f⟩+⟨fn|∑amn|em
=⟨f|f⟩-⟨f|∑amn|em⟩-⟨fn|∑|⟨em|f⟩|em
= ⟨f|f⟩-⟨fn|∑⟨em|f⟩em⟩+⟨fn|∑amn|em⟩-⟨f|∑amn|em
= ⟨f|f⟩-∑⟨em|f⟩⟨fn|em⟩+Σ(amn⟨fn|em⟩-amn⟨f|em⟩)
Now what do I do? I see that I need to get rid of fn, but even with a list of bra-ket rules I can't seem to figure it out.
It is correct that ##\langle e_m|f\rangle\langle f|e_m\rangle=|\langle e_m|f\rangle|^2##.
To prove it, just write ##\langle e_m|f\rangle## as ##a+bi## and use the facts that ##\langle e_m|f\rangle=\langle f|e_m\rangle^*## and ##|a+bi|=\sqrt{a^2+b^2}##.
Likes Vitani11
Awesome. That helps a lot. Can I write ∑⟨em|f⟩⟨fn|em⟩ = ∑⟨em|f⟩⟨f|em⟩ = ∑|⟨em|f⟩|2? At least if I can make an argument for fn = f. I think that is what needs to be done at least because that is the final answer for the first part of the equation.
⟨fn| = Σamn|em⟩ this I know. So therefore is its conjugate |fn⟩ equal to Σamn⟨em|?
I would recommend against using the word 'conjugate' in relation to the vector ##|f_n\rangle##. It is natural to talk about the conjugate of the function ##f##, which we denote by ##f^*##, but one doesn't normally talk about the conjugates of vectors, and in most cases the idea of the 'conjugate of a vector' is either meaningless, or means something different from what is intended here. With vectors, one talks about duals. The dual of ##|f\rangle## is ##\langle f|##.
This may seem picky, as in this context it is natural to identify the function ##f## with the vector ##|f\rangle##, but the differences can become important as one goes deeper into Hilbert Space territory. Also, since we are going to all the trouble of treating it as a vector by writing the bar and ket symbols around it, we might as well use vector terminology to refer to it.
Having got that preamble out of the way' let's look at your rephrased question: 'is ##\sum_m a^m{}_n|e_m\rangle## the dual of ##\sum_m a^m{}_n\langle e_m|##?'
To answer that, let's think about this
$$\sum_m a^m{}_n|e_m\rangle
=\sum_m |a^m{}_n\,e_m\rangle$$
and the dual of this is
$$\sum_m \langle a^m{}_n\,e_m|$$
What happens to the coefficients ##a^m{}_n## when we take them outside of that bra?
Likes Vitani11
If you take the amn out of the bra you will only have a basis and some scalar... so it will give you the sum over some scalar from n to m, but if it is a coefficient it doesn't change. Therefore amn is simply a and would then be able to be taken out of the whole summation. I don't know - can you do that? but then you would get a sum over all basis vectors which just sounds funny without components until you introduce the amn again. Sorry, this might have sounded ridiculous.
That depends on whether the vector space is over the Real or the Complex numbers. Which one is it in this case?
Likes Vitani11
Okay, so if the vector space is over real numbers it does not change but for a vector space over complex numbers the coefficient changes? Can you explain how this is? If I sum over all components of a vector in the complex plane the coefficient changes because the coefficient is itself a basis... As in there is one component which is real and one which is imaginary for the basis of the complex plane
Using ##*## to denote conjugate for scalars and dual for vectors, we have
$$|\alpha v\rangle^*=\Big(\alpha|v\rangle\Big)^*=\alpha^*|v\rangle^*=\alpha^*\langle v|$$
Likes Vitani11
FAQ: Bra ket notation for magnitude of two vectors
What is bra ket notation for magnitude of two vectors?
Bra ket notation is a mathematical notation used in quantum mechanics to represent vectors and operators. In this notation, the magnitude of a vector is denoted by the absolute value of the ket vector, which is represented by a vertical bar enclosing the vector inside, such as |v|.
How is bra ket notation different from traditional vector notation?
In traditional vector notation, the magnitude of a vector is denoted by the length of the vector, represented by a single vertical bar, such as |v|. In bra ket notation, the magnitude is represented by the absolute value of the ket vector, which includes both the length and the direction of the vector.
What is the significance of using bra ket notation for magnitude of two vectors in quantum mechanics?
In quantum mechanics, vectors represent physical quantities and operators represent measurements. Bra ket notation allows for a more concise and elegant representation of these quantities, making it easier to perform calculations and analyze data in quantum mechanics.
Can bra ket notation be used for vectors in any dimension?
Yes, bra ket notation can be used for vectors in any dimension. It is a general notation that is not limited to a specific number of dimensions.
Are there any other uses for bra ket notation besides representing vectors in quantum mechanics?
Yes, bra ket notation is also used in linear algebra and functional analysis to represent vectors and operators in a more concise and abstract manner. It is also used in quantum computing and other quantum technologies.
