squelch
- 1
A particle is in the state [itex]|\psi \rangle = \frac{1}{{\sqrt 3 }}|U\rangle + \frac{{a\sqrt {(2)} }}{{\sqrt {(3)} }}i|D\rangle [/itex]. The up state [itex]|U\rangle = \left( {\begin{array}{*{20}{c}}
1\\
\end{array}} \right)[/itex] and the down state [itex]|D\rangle = \left( {\begin{array}{*{20}{c}}
0\\
\end{array}} \right)[/itex] correspond to the z-basis vectors. Detirmine:
a. The value of "a" such that the state is normalized.
b. [itex]\langle U|D\rangle [/itex]
c. The probability of measuring down. [itex]|\langle D|\psi \rangle {|^2}[/itex]
d. The duel vector [itex]\langle \psi |[/itex]
e. The probability amplitude of measuring up.
f. Write out the state [itex]|\psi \rangle [/itex] in terms of right [itex]|R\rangle [/itex] and left [itex]|L\rangle [/itex].
g. What is the probability of measuring right?
h. A measurement is made on our initial [itex]|\psi \rangle [/itex] with our apparatus oriented in the x-direction and [itex]|R\rangle [/itex] was the outcome. Determine the probability of measuring [itex]|U\rangle [/itex] if our apparatus is oriented back in the z-direction.
None, but as a reference I am using http://ocw.mit.edu/courses/physics/...all-2013/lecture-notes/MIT8_05F13_Chap_04.pdf to guide me through the notation.
I'm going to attempt to break this question down best I can as far as I can understand it, but I'm very uncertain (lol) on the details of what I'm doing. I don't want to do cargo-cult physics.
a. I understand that this is the value of a for while the probability [itex]\langle \psi |\psi \rangle = 1[/itex]. It appears that to get there, a should simply equal 1, but it appears there's a possibility that a= 1/i. So, right now my answer is a=1, because I sort of understand the wave function is necessarily a complex function.
b. The probability of measuring up when the state is down should be 0 (zero).
c. It seems the probability of measuring down is a*(2/3) ... or, normalized, just 2/3.
d. The duel vector [itex]\langle \psi |[/itex] is the complex conjugate of [itex]|\psi \rangle [/itex]. So, I might say that [itex]\langle \psi | = \frac{1}{{\sqrt 3 }}|U\rangle - \frac{{a\sqrt 2 }}{{\sqrt 3 }}i|D\rangle [/itex]
e. As a guess, I'd say [itex]\frac{1}{{\sqrt 3 }}[/itex], the coefficient on [itex]|U\rangle[/itex]
f. I feel like I have to make an assumption here: that it's fifty-fifty either way. If so, I might write: [itex]|\psi \rangle = \frac{1}{{\sqrt 2 }}|R\rangle - \frac{1}{{\sqrt 2 }}i|L\rangle [/itex]
g. From that state equation, 1/2.
h. The previous state is lost, so it becomes 1/3.
