Bragg angle and X-ray Radiation
Overall, your solution is on the right track, but just be careful with units and notation when writing out equations. In summary, the maximum energy of the X-ray radiation is 40 keV and the cutoff wavelength is 31 pm. The Bragg equation for constructive interference is 2dsin(Θ) = nλ, and the Bragg angle can be found using sin(Θ) = λ/(2d). The jitter constant can be calculated as d = λ/(2sin(Θ)), with a resulting value of 223 pm*m.
cutecarebear
In an experiment with X-ray radiation, you use a continuous radiation from an X-ray pipe. What is the highest energy of the X-ray radiation you can get if the pipe's acceleration voltage is 40 kV? If we use radiation with double the wavelength of the maximum energy we get enough intensity to do a Bragg scatter experiement with a crystal. We get constructive interference at an angle of 30 degrees (Bragg angle). What's the jitter constant (d) in the crystal?
We have the Bragg equation:
2dsin(Θ)=λm
and the cutoff Equation
λmin= hc/eV
Due to the conservation of energy the maximum energy of the radiation is 40 KeV. The cutoff wavelength is thus 31 pm. A photon with energy of at most 40 keV has wavelength of at least 31 pm.
Then, plugging into the Bragg formula we get:
2dsin30= 62 pm*m
2d(1/2)=62 pm * m
d= 62 pm*m
Is this correct? If anyone can give any advice it would be much appreciated! Thanks in advance.
Your solution is mostly correct, but there are a few things to note. The maximum energy of the X-ray radiation is actually 40 keV, not 40 kV. The Bragg equation should also be written as:
2dsin(Θ)=nλ
Where n is the order of diffraction (in this case, n = 1). Additionally, the Bragg angle should be in radians, so it should be:
sin(Θ) = λ/(2d)
Therefore, the Bragg angle would be:
Θ = sin^-1(31 pm*m/(2*62 pm*m)) = 0.25 radians = 14.3 degrees
To find the jitter constant, we can rearrange the Bragg equation to solve for d:
d = λ/(2sin(Θ))
Plugging in the values, we get:
d = (62 pm*m)/(2sin(14.3 degrees)) = 223 pm*m
So the jitter constant would be 223 pm*m. Note that this is just an approximation, as the actual value would depend on the specific crystal used in the experiment.
Related to Bragg angle and X-ray Radiation
What is the Bragg angle in relation to X-ray radiation?
The Bragg angle is the angle at which X-ray radiation is diffracted by a crystal lattice. It is determined by the spacing of the crystal planes and the wavelength of the X-rays.
How does the Bragg angle affect the intensity of X-ray radiation?
If the Bragg angle is not met, the X-rays will not be diffracted and there will be no intensity. However, if the Bragg angle is met, the intensity of the diffracted X-rays will be high.
Why is the Bragg angle important in X-ray crystallography?
In X-ray crystallography, the Bragg angle is crucial in determining the atomic structure of crystals. By measuring the angles at which X-rays are diffracted, scientists can calculate the positions and arrangements of atoms within a crystal.
How can the Bragg angle be calculated?
The Bragg angle can be calculated using the Bragg equation: nλ = 2dsinθ, where n is the order of diffraction, λ is the wavelength of X-rays, d is the spacing between crystal planes, and θ is the Bragg angle.
What are some practical applications of the Bragg angle and X-ray radiation?
The Bragg angle and X-ray radiation have many practical applications in various fields such as materials science, medicine, and forensics. They are used to determine the structure of crystals, analyze the composition of materials, and diagnose medical conditions, among others.
