Braking distance of a car(forces and friction)
In summary, the driver of a 1500 kg car traveling at 12.5 m/s can calculate the braking distance by using the equation W = K_f - K_i, where the final kinetic energy (K_f) is equal to half the mass of the car multiplied by its velocity squared. The initial kinetic energy (K_i) is zero since the car is coming to a stop. The friction force is found by multiplying the normal force by the coefficient of friction. The distance is then calculated by dividing the work by the friction force, resulting in a braking distance of 10.84m.
chaotiiic
the driver of a 1500 kg car traveling at 12.5 m/s slams on the brakes, locking the wheels, and bringing the car to a stop. If the coefficient of friction is .735, what is the braking distance of the car?
W = K_f - K_i
friction force
K_f = (1/2)(1500)(12.5)^2 = 117187.5
K_i = 0
W = 117187.5
F_n = 14700
friction force = 14700 * .735 = 10804.5
distance = 117187.5/10804.5 = 10.84m
correct?
Hi, chaotiiic,
The result is correct.
ehild
ehild said:
Hi, chaotiiic,
ehild
i can't find this in my book but why does normal force need to be multiplied with friction coefficient in order to get friction force? does friction force have a unit?
and why does Work need to be divided by friction force in order to get the distance? is there a name for this equation?
The force of friction is proportional with the force that presses two surfaces together. This force is normal to the surface of touch, parallel with it and opposes any relative motion of the objects. It is a force, so the unit is Newton (N) There is kinetic friction, when the surfaces slide on each other, and static friction which prevents any relative motion. The magnitude of kinetic friction is FKKN, the static friction is the force needed to prevent relative motion, and FS≤μSN.
Work is defined as the scalar product of the force vector F and displacement vector d. If the force and displacement are parallel, W=Fd. The work is positive when the force and displacement have the same direction, and negative when the force points in opposite direction as the motion.
You certainly find these in your textbook...
ehild
Your solution is correct. The braking distance of the car in this scenario would be 10.84 meters. This calculation takes into account the kinetic energy of the car and the friction force acting on it to bring it to a stop. It is important to consider these forces when driving and to maintain a safe distance from other vehicles to allow for proper braking distance. Additionally, this calculation can be used to compare different scenarios, such as changing the speed or weight of the car, to determine the impact on the braking distance.
Related to Braking distance of a car(forces and friction)
1. What factors affect the braking distance of a car?
The braking distance of a car is affected by several factors, including the speed of the car, the condition of the brakes, the weight of the car, the road conditions, and the coefficient of friction between the tires and the road surface.
2. How does the speed of a car affect its braking distance?
The higher the speed of a car, the longer its braking distance will be. This is because the car has a greater momentum and requires more force to slow down and come to a complete stop.
3. How does the weight of a car affect its braking distance?
The weight of a car also plays a role in its braking distance. A heavier car has a greater momentum and therefore requires more force to slow down, resulting in a longer braking distance compared to a lighter car.
4. What is the role of friction in the braking distance of a car?
Friction between the tires and the road surface is essential in reducing the speed of a car and bringing it to a stop. The more friction there is between the tires and the road surface, the quicker the car will decelerate and the shorter the braking distance will be.
5. How can the braking distance of a car be reduced?
The braking distance of a car can be reduced by maintaining good road conditions, regularly checking and maintaining the brakes, and driving at a safe speed. Additionally, using tires with a higher coefficient of friction can also help decrease the braking distance of a car.
