Branch points of a complex function
  • Thread starter Thread starter Hill
    Complex function
Hill
Consider the multifunction ##f(z) = \sqrt {z - 1} \sqrt[3] {z - i}##.
Where are the branch points and what are their orders?
##e^{i \frac \theta n} = e^{i \frac {\theta + 2 \pi n} n}##
My answer: one branch point is ##1## of the order 1, another is ##i## of the order 2.
My question is, how can I be sure that these are the only branch points?
Prove by construction that, at an arbitrary point in the complex plane excluding 1 and ##i##, each branch of the function ##f## has a continuous inverse. At least one branch of a function does not have a continuous inverse at a branch point. So if every branch has a continuous inverse, it cannot be a branch point.
Likes Hill and WWGD
Yes, good point, branch point of product doesn't necessarily coincide with the intersection of the branch points. Could this be expressed in terms of the monodromy groups?
If I understand this test correctly:
Let's take a simpler function, ##f(z)=\sqrt z##. It has branch point at 0.
The inverse of this function is ##z(f)=f^2##.
Isn't ##z(f)## continuous everywhere, including the branch point ##f(0)=0##?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
