Branching ratio for one decay channel
In summary, the branching ratio for one decay channel refers to the probability or fraction of a particle decaying through a specific pathway compared to all possible decay pathways. It quantifies how often a particular decay mode occurs relative to others, allowing for insights into the underlying processes and interactions governing particle behavior. Understanding branching ratios is essential in particle physics for predicting outcomes of decays and for experimental analyses.
zaman786
31
TL;DR Summary
how can we find the branching ratio - after do calculation for one channel
hi, for studying one decay channel of particle - and measuring its decay width or life time - after this how do we proceed to find the branching ratio -
do we need to find the decay width of all possible channel - because its possible even by experiment we are missing some possible decay mode.
kindly help
Where are you starting from? Can't give you directions from here to there without knowing where "here" is.
for example D0 meson has several semi-leptonic decay - i want to find its branching ratio for k-, positron and electron neutrino , i can find its decay width
but it has different mode or channel also exist as mention in PDG , so do i have to find decay width for all of these modes and get total decay width. than by using formula : Branching ratio = partial decay width/ total decay width
or there exist some easiest approach
Likes ohwilleke
If you want to do this purely theoretically then you need to calculate all decay modes, or at least all major decay modes and then neglect the rare ones. Typically theoretical results will compare one branching fraction to another, the ratio won't be affected by other decay modes. That is easier to measure experimentally as well.
Likes ohwilleke and vanhees71
thanks a lot for clearing my confusion
Calculating all possible channels is how you would make the theoretical calculation.
You could also do an inclusive measurement of the decay width of the entire hadron (looking at its resonance) which would measure the total decay width, including decays that are rare enough to not be detected individually.
Rare decays are so uncommon, and the measurements of total decay width and single channel decay widths have sufficient uncertainty (often 10-3 or worse), that missing a few rare decays (which often have branching fractions of 10-5 or less), doesn't change the branching fraction enough to be distinguishable given the uncertainties involved in your other calculations and measurements. So, you can safely omit rare decays from the theoretical total decay width without materially changing the accuracy of your calculation.
surely, you have given hint - looking at its resonance - thanks , i will look into it-
thanks a lot
Likes ohwilleke
FAQ: Branching ratio for one decay channel
What is a branching ratio in the context of particle decay?
A branching ratio is the fraction of a particular decay mode or channel of a particle relative to the total number of decays. It quantifies the likelihood of a specific decay path compared to all possible decay paths.
How is the branching ratio calculated?
The branching ratio is calculated by dividing the number of decays via a specific channel by the total number of decays of the particle. Mathematically, it is expressed as BR = (Number of decays via specific channel) / (Total number of decays).
Why is the branching ratio important in particle physics?
The branching ratio provides crucial information about the underlying physics and interactions governing particle decays. It helps in understanding the properties of particles, verifying theoretical models, and searching for new physics beyond the Standard Model.
What units are used to express branching ratios?
Branching ratios are dimensionless quantities and are typically expressed as percentages or fractions. For example, a branching ratio of 0.25 can be expressed as 25%.
Can branching ratios change, and if so, under what conditions?
Branching ratios are generally constant for a given particle under specific conditions. However, they can change if external conditions such as temperature, pressure, or the presence of external fields alter the decay dynamics. Additionally, new discoveries or more precise measurements can refine the known branching ratios.
