Breakdown of Correspondence Principle: Null Dust Case
In summary: Therefore, the correspondence principle does not apply here.In summary, the conversation discusses the limitations of applying the correspondence principle in both quantum and general relativity theories. It is pointed out that in the case of a null dust solution in Einstein's field equations, the concept of massless particles and Newtonian gravity cannot be applied. This is because Newtonian gravity requires small masses and velocities, while a null dust is made up of particles traveling at the speed of light. Therefore, the correspondence principle cannot be used in this scenario.
victorvmotti
155
In both quantum and general relativity theories we are used to provide results in the "limited" conditions to demonstrate a correspondence between new and old formalism.
For instance deflection of light of a star due to Sun in GR is double the amount given in classical theory.
Yet I have problems to sense a limit condition on the gravity due to pure radiation also called null dust solution of Einstein's field equation for a perfect pressureless fluid.
If we tend to zero both the masses on the Newtown gravity law the force among the objects/particles will be zero.
But based on Einstein's field equation the energy momentum tensor does not vanish in the case of massless objects and is defined in terms of two null four velocities which is the equation for a dust with zero pressure. Therefore the nonvanishing curvature tensor says that a group of massless particles have gravity among themselves.
Is this a correct understanding?
And is it a counter example to correspondence principal in GR?
It is not enough to have small masses for the limit to norelativistic gravity. You also need the objects to have small velocities (and the stresses need to be smaller than the energy dencity).
Likes bcrowell
Yes you are right, my point is that a correspondence cannot be made given the nature of Newton law.
In Newtonian gravity, yes. But you can't use Newtonian gravity to describe null dust, or in fact to describe anything "massless". That concept simply doesn't exist in Newtonian gravity.
Yes.
What "correspondence principle" are you talking about? Can you give a reference?
I am trying to imagine what the cosmos looked like or its dynamics in the radiation dominated era after Big Bang. Thought that a correspondence with Newton law in the limits might be helpful.
Sean Carroll in his Spacetime and Geometry book adopts a sort of correspondence approach in Chapter 4, pp 151-159 where he argues if the new theory by Einstein predicts the Newtonian theory.
People more frequently use "correspondence principle" to refer to classical physics as compared to quantum mechanics, but the idea is broader. As applied to relativity, one way of expressing it is to say that relativity has to be consistent with Newtonian mechanics in the limit of weak gravitational fields and velocities much less than c.
For the OP, the problem is that, as pointed out by martinbn, the relevant limit does not apply here. A null dust is made of particles traveling at c, and that's the opposite of the Newtonian limit.
Likes martinbn
Related to Breakdown of Correspondence Principle: Null Dust Case
1. What is the Correspondence Principle?
The Correspondence Principle is a fundamental concept in physics that states that the behavior of systems described by a new theory should correspond to the behavior predicted by the previous theory in cases where the previous theory is known to be valid.
2. What is the Breakdown of Correspondence Principle?
The Breakdown of Correspondence Principle refers to situations where the behavior predicted by a new theory does not match the behavior predicted by the previous theory, even in cases where the previous theory is known to be valid. This can happen when the new theory is describing extreme or novel conditions that were not considered in the previous theory.
3. What is the Null Dust Case?
The Null Dust Case is a specific scenario used to study the Breakdown of Correspondence Principle. It involves a universe filled with a hypothetical substance called "null dust" that has properties that are not accounted for in the previous theory. This case allows for the study of the behavior of the new theory in extreme conditions.
4. How is the Breakdown of Correspondence Principle related to General Relativity?
The Breakdown of Correspondence Principle was first identified in the study of General Relativity, which is a theory that describes gravity and the structure of the universe on a large scale. The null dust case is often used in the study of General Relativity to explore the behavior of the theory in extreme conditions.
5. What are the implications of the Breakdown of Correspondence Principle?
The Breakdown of Correspondence Principle has important implications for our understanding of the laws of physics. It suggests that there may be situations where our current theories are not applicable and that there may be new physical phenomena that are not accounted for in our current understanding. It also highlights the need for further research and development of new theories to fully explain the behavior of the universe.
