I Breaking the Light Speed Barrier?
SWIRF
If we have a pair of super-asymmetrical entwined particles, and move them a light year away so that they retain their quantum entanglement, and we set a clockwise spin as 0 and a counter-clockwise spin as 1. Would it be possible to transmit binary data faster than the speed of light?
If we hold that quantum entanglement has no distance limitations and changes to one happen instantaneously to the other, would that not be a method for transmitting data faster than the speed of light? Even if it is just a binary operation. But what if we had a cluster of these particles?
could 100 entwined pairs on each side be used to multithread binary data faster than light speed?
or a billion?
No.
Indeed, altering one pair of entangled particles does nothing to the other, just as dying one sock of a pair doesn't change the other.
"For example, if two entangled particles are measured in quick succession, the measurement of one particle can instantaneously affect the other particle, no matter how far apart they are. This is because the particles become correlated, meaning that if one particle changes its state, the other particle will undergo the same change. For example, if you measure the spin direction of one entangled particle and it's to the right, you can know that the other entangled particle's spin direction will be to the left. "
SPACE.COM
Is quantum entanglement faster than light?​
Asking about speed is a very interesting question. You might as a "normal human being" think that if I measure the polarization of one photon, that sets the state of the other photon. That thinking is fine, as long as the other photon measurement happens after the first measurement. But there is already a problem. If that second photon is measured on Pluto, it might take 6 hours for light to get there, so because information cannot travel faster than the speed of light, the second photon wouldn't know what state it should be. But it turns out that that second measurement will always match the first no matter when it was measured. So, it seems like the necessary information must have traveled faster than the speed of light. Big problem, but entanglement's weirdness gets it out of an astronomical speeding ticket.
In the case of entanglement, the information that appears at your Pluto measurement station is not useful information (in the ordinary sense). It is random just like the random result that came out of that first measurement (but matching random). So, the key point is that you could not take advantage of news of a crop failure and send a buy or sell order to your stockbroker on Pluto at faster than the speed of light before the Plutonian markets had time to adjust. It is only "randomness" that appears to travel faster than light, so the galactic traffic cop just lets you off with a warning."
the information wouldn't be useless if we assigned binary states to spin states or polarization states.
If we found a way to dye one of these socks, the other would in fact change color as well :)
@SWIRF your space.com reference is a pop science article. Those are not good sources for learning actual science. @Vanadium 50 gave you the correct answer to your question: you can't use entanglement to send information faster than light.
Likes Vanadium 50 and Dale
Moderator's note: Thread level changed to "I".
The OP question has been answered. Thread closed.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I am looking at the Laughlin wave function and it contains the term $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q$$ In Wikipedia the lower index on ##\Pi## is ##1\le i<j\le N## and there is no upper index. I'm not sure what either mean. For example would $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q=\prod_{k=2}^{N}\left[\prod_{j=1}^{k-1}\left(z_j-z_k\right)^q\right]?$$ (It seems that ##k## cannot be 1 because there would be nothing to multiply in the second product). I'm not sure what else the...
