Brewster's angle, dipole radiation and refraction
In summary: The Brewster angle is the angle between the plane of incidence and the plane of reflection of light in a medium. It is named after English physicist George Brewster. Incoming light is always incident at an angle to the surface of a material, and is refracted in such a way that its polarization is altered. If the angle between the incoming light and the normal to the surface is equal to the Brewster angle, then the light is reflected in a straight line. If the angle between the incoming light and the normal to the surface is greater than the Brewster angle, then the light is refracted and reflected in a curved line. If the angle between the incoming light and the normal to the surface is less than the Brewster
Aetholite
So I was wondering how it is possible that there will be no p-pol light reflected when the refracted light is at 90 degrees to the reflected light (so incoming light is at Brewster's angle).
The Brewster's angle was explained to me by saying that the electrons in the medium radiate light (EM-waves), because they osciallate due to the incoming light wave. This radiation is zero in the direction of the electron (dipole) oscillation, thus when the osciallation direction is the same direction as the reflected light would be, no light would be radiated in that direction, and thus no reflection would take place. This being the case only for p-pol light.
But my question is: Doesn't this imply that the electrons oscillate at a diferent angle (refraction angle) and not oscillate at the same angle as the incoming light? I thought the refraction angle was due to the superposition of radiated light from these electrons and not already present at each individual electron. If that is the case, why would electrons oscillate at a different angle (refraction angle) in the receiving medium than they do in the incidence medium?
Could someone explain to me how the brewster angle and refraction work on a miscroscopic level, without it depending on a macroscopic interpretation of light refraction.
Science news on Phys.org
The incoming light changes direction because it slows down in the second medium. That is Snell's Law and not part of electromagnetics (it also happens with sound, for instance).
The new light beam is now in a direction perpendicular to the Brewster Angle, so you are correct, the E vector of the refracted ray is edge on to the reflected ray, giving zero amplitude for the parallel polarisation.
There is a lecture by Prof Lewin at this URL which does it more formally by deriving the Fresnel equations. These give us the intensity of each ray based on the incident angle and the refractive indices.
Likes vanhees71
"The polarization of freely propagating light is always perpendicular to the direction in which the light is travelling. The dipoles that produce the transmitted (refracted) light oscillate in the polarization direction of that light. These same oscillating dipoles also generate the reflected light. However, dipoles do not radiate any energy in the direction of the dipole moment. If the refracted light is p-polarized and propagates exactly perpendicular to the direction in which the light is predicted to be specularly reflected, the dipoles point along the specular reflection direction and therefore no light can be reflected."
From https://en.wikipedia.org/wiki/Brewster's_angle
Related to Brewster's angle, dipole radiation and refraction
What is Brewster's angle?
Brewster's angle, also known as the polarization angle, is the angle at which light incident on a surface will be completely polarized. This means that the reflected light will have only one polarization (either parallel or perpendicular to the surface), while the transmitted light will have the opposite polarization. At Brewster's angle, there is no reflection of light with the perpendicular polarization.
How is Brewster's angle related to refraction?
Brewster's angle is related to refraction in that it occurs when the incident light is refracted at an angle that is parallel to the surface. This means that the refracted light will not experience any change in polarization, and therefore there will be no reflection of light with that polarization. This phenomenon is known as total internal reflection.
What is dipole radiation?
Dipole radiation is the type of electromagnetic radiation emitted by an oscillating electric dipole. This occurs when an electric charge is accelerated or decelerated, causing it to emit electromagnetic waves. Dipole radiation is an important concept in understanding the behavior of light and other electromagnetic waves.
How is dipole radiation related to refraction?
Dipole radiation is related to refraction in that it is the mechanism by which light is emitted or absorbed by atoms and molecules during the process of refraction. When light is refracted, the atoms and molecules in the material are disturbed, causing them to emit or absorb electromagnetic waves. This results in the change in direction of the light as it passes through the material.
What is the role of refraction in optics?
Refraction plays a crucial role in optics as it is the bending of light as it passes through different materials. This phenomenon allows for the creation of lenses and other optical instruments that manipulate light for various purposes. Refraction is also responsible for the formation of rainbows and other optical illusions, and it is essential in our understanding of how light behaves in different mediums.
  • Thermodynamics
