- 2,076
- 140
The output of the transformer is a sinusoidal AC signal with ##10.6V## RMS amplitude, and acts as an input to the bridge rectifier.
Explain the operation of the following bridge rectifier circuit.
Then sketch the output waveform ##V_L## assuming the ##0.7V## drop model for the silicon diodes.
I want to make sure I understand the operation of this circuit correctly.
The output of the the transformer acts as the input to the bridge rectifier circuit, call the input ##v_s##. The input will have a maximum amplitude given by ##V_p = (10.6 V)\sqrt{2} = 15 V##.
During the positive half cycles of the input voltage, ##v_s## is positive, and current is conducted through ##D_1, D_L, R_L## and ##D_4##. The diodes ##D_2## and ##D_3## are reversed biased during this time. The output voltage ##V_L## will be lower than ##v_s## by two ##0.7V## diode drops and a ##1.5V## LED drop (I've been told to assume LEDs have a 1.5 V drop). So the maximum amplitude of ##V_L## would be ##12.1 V##.
During the negative half cycles of the input voltage, ##v_s## is negative, so ##-v_s## is positive. Current will be conducted through ##D_2, D_L, R_L## and ##D_3##. The diodes ##D_1## and ##D_4## are reversed biased during this time. The output voltage ##V_L## will be lower than ##v_s## by two ##0.7V## diode drops and a ##1.5V## LED drop. So the maximum amplitude of ##V_L## would be ##12.1 V##.
Does this sound okay? Thank you for your help in advance.
