Broadening of emission peak - "red/blue spike"
In summary, the spectral emission peak can broaden due to high temperature of the emitter, resulting in a "red/blue spike" effect. This is not due to Doppler broadening, but rather the absorption of emitted energy by colder CO2 in the atmosphere. The right formulas and more information on this phenomenon can be found in the paper "Theory of the Red-Blue Spike in High-Temperature Rotational Spectra" by Jellison et al.
AlexVM
As I understand, spectral emission peak can broaden due to high temperature of the emitter.
For example, emission of "cold" CO2 will have a thin peak at 4.3um while the CO2 emitted from a (very hot) rocket plume will have a broad emission at ~4um - 4.7um (called "red/blue spike")
What is the physical reason for this phenomenon?
Where can I find the right formulas?
Thanks,
Alex
Thanks,
Alex
This is called Doppler broadening.
Thanks,
Alex
The observed effect is not due to Doppler broadening of a single line. It is actually something much more complicated.
This paper discusses the origin of this effect: http://www.dpinstruments.com/papers/5093-20_theory_jellison.pdf
In the paper above, Figure 1 shows what the spectrum should look like. Figure 8 shows the observed spectrum above a portable exhaust stack.
The blue-red spikes refer to the appearance of a ro-vibrational CO2 emission spectrum that comes from a hot emitter of CO2 radiation, whose emission spectrum passes through a colder sample of CO2.
The peaks due to transitions from high J states (high rotational states) that occur in a hot sample are the ones that have little attenuations (there is relatively little CO2 in these high energy states). The peaks due to transitions from low-J states are reabsorbed by the cold CO2 between emitter and abosrber. Because of this, the central portion of the spectrum (due to the low rotational energy CO2 states) is "missing."
From the paper above:
"An additional difficulty is caused by atmospheric absorption. In field measurements on plumes, the "pure" spectrum
often will not be observable. The emitted energy passes through some path length of air before it is received by the
spectrometer, and if one is observing plume emission from CO2 (for example), the emitted energy can be partially
absorbed by the CO2 in the air. This absorption will cause a "hole" around the line center. Only the outer edges of the
branches (the so-called red and blue spikes) will be observable. Standard laboratory techniques may not be appropriate
to remote measurements of molecular transitions that are subject to significant absorption by the intervening air."
Related to Broadening of emission peak - "red/blue spike"
1. What is the broadening of emission peak in relation to the "red/blue spike" phenomenon?
The broadening of emission peak refers to the increase in the width of the emission peak of a light source, such as a laser or LED. In the case of the "red/blue spike" phenomenon, this refers to a broadening of the red and blue emission peaks, resulting in a spike in the middle of the spectrum.
2. What causes the broadening of emission peak?
The broadening of emission peak can be caused by a variety of factors, including temperature changes, changes in the material composition, and defects in the light source. In the case of the "red/blue spike" phenomenon, it is often caused by temperature fluctuations or imperfections in the light source.
3. How does the broadening of emission peak affect the performance of a light source?
The broadening of emission peak can have a significant impact on the performance of a light source. It can result in a decrease in the intensity of the emitted light, changes in the color or wavelength of the light, and a decrease in the overall efficiency of the light source.
4. Can the broadening of emission peak be controlled or minimized?
Yes, the broadening of emission peak can be controlled or minimized through various methods. This can include improving the material composition of the light source, implementing temperature control measures, and utilizing advanced manufacturing techniques to reduce defects.
5. Are there any potential applications for the "red/blue spike" phenomenon?
The "red/blue spike" phenomenon has been observed in a variety of light sources, including lasers and LEDs. While it is often seen as a defect or undesirable characteristic, it has also been utilized in certain applications, such as in medical imaging or in the creation of specific colors in displays.
  • Quantum Physics
  • Quantum Physics
