A Brownian Motion (Langevin equation) correlation function
The Langevin equation of Brownian motion is a stochastic differential equation that describes the motion of particles in a fluid, incorporating both friction and random forces. The correlation function of the noise term is derived from the fluctuation-dissipation theorem, linking the random force's strength to the temperature of the system. To calculate the correlation function, one can derive the Fokker-Planck equation or evaluate the expectation value of kinetic energy using the equipartition theorem. The solution involves the Green's function, leading to expressions for the velocity and its fluctuations over time. Ultimately, the diffusion coefficient is confirmed as D = λk_B T, validating the connection between dissipation and fluctuation in the system.
Tim667
TL;DR Summary
How does one calculate the correlation function?
So the Langevin equation of Brownian motion is a stochastic differential equation defined as
$$m {d \textbf{v} \over{dt} } = - \lambda \textbf{v} + \eta(t)$$
where the noise function eta has correlation function $$\langle \eta_i(t) \eta_j(t') \rangle=2 \lambda k_B T \delta_{ij} \delta(t - t')$$.
I have two questions. How does one actually calculate a correlation function and where exactly do the constants (with temperature, the Boltzmann constants etc) proceeding the delta functions originate here? I understand that the delta functions ensure that there is no correlation at different times etc, but I don't get where the rest comes from.
Thanks
That's the fluctuation-dissipation theorem. It's one of Einstein's most famous results from his "miracle year" 1905. There are two ways to answer your question. One is to derive the Fokker-Planck equation for the probability distribution function ##f(t,\vec{v})## and show that the stationary solution is the Maxwell-Boltzmann distribution with temperature ##T##, as it should be.
The other is to evaluate the expectation value of the kinetic energy and use the equipartition theorem for the long-time limit. In other words we have to calculate ##\langle \vec{v}^2(t)##. To do that we can formally solve the stochastic differential equation, using the Green's function of the "deterministic part", i.e., we look for
$$m \dot{G}(t)+\lambda G(t)=\delta(t). \qquad (*)$$
For ##t \neq 0## we have
$$G(t)=A \exp(-\gamma t), \quad \gamma=\lambda/m.$$
Since we want a "causal Green's function" we make ##G(t)=0## for ##t<0## and determine ##A## for ##t>0## such that we get the right singularity. So we integrate (*) over a small interval ##(-\epsilon,\epsilon)## and make ##\epsilon \rightarrow 0^+## to get
$$m A=1 \; \Rightarrow \; A=1/m.$$
So we have
$$G(t)=\Theta(t) \frac{1}{m} \exp(-\gamma t).$$
Then the formal solution of the Langevin equation is (for ##t>0##)
$$\vec{v}(t)=\vec{v}_0 \exp(-\gamma t) + \int_0^t \mathrm{d} t' G(t-t') \eta(t')=\vec{v}_0 \exp(-\gamma t) + \vec{v}_{\text{fluct}}(t).$$
From this we get
$$\vec{v}^2(t) = \vec{v}_0^2 \exp(-2 \gamma t) + 2 \vec{v}_0 \cdot \vec{v}_{\text{fluct}}(t) \exp(-\gamma t) + \vec{v}_{\text{fluct}}^2(t).$$
Taking the expectation value, we get because of ##\langle \vec{\eta}(t)=0##
$$\langle \vec{v}^2(t) \rangle=\vec{v}_0^2 \exp(-2 \gamma t) +\langle \vec{v}_{\text{fluct}}^2(t) \rangle.$$
Now
$$\langle \vec{v}_{\text{fluct}}^2(t) \rangle=\int_0^t \mathrm{d} t_1 \int_0^t \mathrm{d} t_2 G(t-t_1) G(t-t_2) \langle{\eta_j(t_1) \eta_j(t_2)}=\int_0^t \mathrm{d} t_1 \int_0^t \mathrm{d} t_2 6 \lambda k_{\text{B}} T \delta(t_1-t_2)G(t-t_1) G(t-t_2).$$
Evaluating the integral leads finally to
$$\langle \vec{v}_{\text{fluct}}^2(t) \rangle=\frac{3 k_{\text{B}} T}{m}[1-\exp(-2 \gamma t)].$$
For ##t \rightarrow \infty## we thus get
$$\frac{m}{2} \langle \vec{v}^2(t) \rangle \rightarrow \frac{3}{2} k_{\text{B}} T,$$
as it should be in the equilibrium limit according to the equipartition theorem. So the diffusion coefficient ##D=\lambda k_{\text{B}} T## as assumed is the correct choice. That's known as dissipation-fluctuation theorem, because it connects the friction coefficient ##\lambda## ("dissipation") to the strength of the random force in the Langevin equation, which is describing (from a macroscopic point of view) the "diffusion" of the heavy particle in the heat bath made up by the light particles.
Likes anuttarasammyak and Tim667
So we have
From this we get
Now
Thank you! Brilliant answer
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
