Bruno's question at Yahoo Answers (Tangent line to an ellipse).
  • MHB
  • Thread starter Fernando Revilla
  • Tags
    Ellipse Line
In summary, to find the equation of the tangent line to the given ellipse with slope 1, you can use either the method of substitution or differentiation to find the two possible x values. From there, you can use the slope and point formula to find the equations of the two tangent lines, which are $y=x-1$ and $y=x+\dfrac{13}{3}$.
Fernando Revilla
MHB
631
Here is the question:
3x^2+y^2+4x-2y=3 Find the equation of the tangent line to that ellipse with slope 1.
I know how to write it in the canonic form but then i don't know what to do.
Answer: x-y-1=0
Here is a link to the question:
Tangent line to a ellipse? - Yahoo! Answers
Mathematics news on Phys.org
Hello Bruno,
The equation of a line with slope $1$ is $r:y=x+b$. If the line is tangent to the ellipse, the intersection must be only one point. Substituting in the ellipse:
$3x^2+(x+b)^2+4x-2(x+b)-3=0$
Equivalently:
$4x^2+(2b+2)x+b^2-2b-3=0$
The discriminat $D=B^2-4AC$ must be $0$:
$D=(2b+2)^2-16(b^2-2b-3)=0$
Simplifying:
$3b^2-10b-13=0\Leftrightarrow b=-1\vee b=13/3$
So, there are two solutions:
$y=x-1,\;y=x+\dfrac{13}{3}$
An alternative method:
Your tangent line is $\displaystyle \begin{align*} 3x^2 + y^2 + 4x - 2y = 3 \end{align*}$. Differentiating both sides with respect to x gives
$\displaystyle \begin{align*} \frac{d}{dx} \left( 3x^2 + y^2 + 4x - 2y \right) &= \frac{d}{dx} \left( 3 \right) \\ 6x + 2y\,\frac{dy}{dx} + 4 - 2\,\frac{dy}{dx} &= 0 \\ 6x + 4 &= \left( 2 - 2y \right) \frac{dy}{dx} \\ 3x + 2 &= \left( 1 - y \right) \frac{dy}{dx} \\ \frac{3x + 2}{1 - y} &= \frac{dy}{dx} \end{align*}$
You know that the slope is 1 at that point, so that means
$\displaystyle \begin{align*} \frac{3x + 2}{1 - y} &= 1 \\ 3x + 2 &= 1 - y \\ 3x + 1 &= -y \\ -3x - 1 &= y \end{align*}$
Substituting into the original equation for your ellipse gives
$\displaystyle \begin{align*} 3x^2 + y^2 + 4x - 2y &= 3 \\ 3x^2 + \left( -3x - 1 \right)^2 + 4x - 2 \left( -3x - 1 \right) &= 3 \\ 3x^2 + 9x^2 + 6x + 1 + 4x + 6x + 2 &= 3 \\ 12x^2 + 16x + 3 &= 3 \\ 12x^2 + 16x &= 0 \\ 4x \left( 3x + 4 \right) &= 0 \\ 4x = 0 \textrm{ or } 3x + 4 &= 0 \\ x = 0 \textrm{ or } x &= -\frac{4}{3} \end{align*}$
And since we know $\displaystyle \begin{align*} y = -3x - 1 \end{align*}$, that means the two points on the ellipse which have a tangent line of slope 1 are $\displaystyle \begin{align*} (0, -1) \end{align*}$ and $\displaystyle \begin{align*} \left( -\frac{4}{3} , 3 \right) \end{align*}$.
Each tangent line will be of the form $\displaystyle \begin{align*} y = mx + c \end{align*}$, so in the first tangent line:
$\displaystyle \begin{align*} -1 &= 1(0) + c \\ -1 &= c \end{align*}$
and in the second tangent line:
$\displaystyle \begin{align*} 3 &= 1 \left( -\frac{4}{3} \right) + c \\ 3 &= -\frac{4}{3} + c \\ \frac{13}{3} &= c \end{align*}$So your two tangent lines are $\displaystyle \begin{align*} y = x - 1 \end{align*}$ and $\displaystyle \begin{align*} y = x + \frac{13}{3} \end{align*}$.
FAQ: Bruno's question at Yahoo Answers (Tangent line to an ellipse).
What is the equation for finding the tangent line to an ellipse?
The equation for finding the tangent line to an ellipse at a given point (x0, y0) is y - y0 = (y0 - b^2/a^2x0)/sqrt(a^2 - b^2)(x - x0), where a is the length of the semi-major axis and b is the length of the semi-minor axis.
How do you find the point of tangency on an ellipse?
The point of tangency on an ellipse can be found by setting the derivative of the ellipse equation equal to the slope of the tangent line and solving for the x-coordinate. Then, the y-coordinate can be found by plugging the x-coordinate into the original ellipse equation.
Can a tangent line intersect an ellipse at more than one point?
No, a tangent line can only intersect an ellipse at one point. This is because a tangent line is defined as a line that touches a curve at only one point without crossing over it.
How do you determine the direction of the tangent line to an ellipse?
The direction of the tangent line to an ellipse at a given point can be determined by finding the slope of the tangent line, which is equal to the derivative of the ellipse equation at that point. The direction of the tangent line will be parallel to the major axis of the ellipse at that point.
Is the tangent line to an ellipse always perpendicular to the radius vector?
Yes, the tangent line to an ellipse is always perpendicular to the radius vector (line connecting the center of the ellipse to the point of tangency). This is a property of ellipses known as the "normal property", which states that the tangent line and radius vector at a point on an ellipse are always perpendicular to each other.
