MHB Bryan's question at Yahoo Answers regarding linear recurrence relations
The discussion addresses Bryan's question on solving two linear recurrence relations. For the first relation, An = An-1 + 6An-2 with initial conditions A0 = 3 and A1 = 6, the closed form is derived as An = 3·2^(n-1)(-1)^n + 3^n. The second relation, An+2 = -4An+1 + 5An with A0 = 2 and A1 = 8, leads to the closed form An = 3 - (-5)^n. The solutions involve finding characteristic equations and roots, followed by determining parameters using initial values. The thread encourages further questions on similar topics.
MarkFL
MHB
Here is the question:
Discrete Mathematics Question?
Find the solution to recurrence relations.
A) An = An-1 + 6 An-2 , Ao = 3 , A1 = 6B) An+2 = -4 An+1 + 5 An , A0 = 2 , A1 = 8
Here is a link to the question:
Discrete Mathematics Question? - Yahoo! Answers
I have posted a link there to this topic so the OP may find my response.
Mathematics news on Phys.org
Hello Bryan,
A) We are given the recurrence relation
$$A_{n}=A_{n-1}+6A_{n-2}$$ where $$A_0=3,\,A_1=6$$
The associated characteristic equation is:
$$r^2-r-6=(r+2)(r-6)=0$$
Our characteristic roots are then $$r=-2,\,6$$
Hence, the closed form is:
$$A_n=k_1(-2)^n+k_2(6)^n$$
We may use the initial values to determine the parameters $k_i$:
$$A_0=k_1(-2)^0+k_2(6)^0=k_1+k_2=3$$
$$A_1=k_1(-2)^1+k_2(6)^1=-2k_1+6k_2=6\,\therefore\,-k_1+3k_2=3$$
Solving this 2X2 system, we find:
$$k_1=k_2=\frac{3}{2}$$ and so:
$$A_n=\frac{3}{2}\left((-2)^n+6^n \right)=3\cdot2^{n-1}\left((-1)^n+3^n \right)$$
B) We are given the recurrence relation:
$$A_{n+2}=-4A_{n+1}+5A_{n}$$ where $$A_0=2,\,A_1=8$$
$$r^2+4r-5=(r+5)(r-1)=0$$
Our characteristic roots are then $$r=-5,\,1$$
$$A_n=k_1(-5)^n+k_2$$
$$A_0=k_1(-5)^0+k_2=k_1+k_2=2$$
$$A_1=k_1(-5)^1+k_2=-5k_1+k_2=8$$
$$k_1=-1,\,k_2=3$$ and so:
$$A_n=3-(-5)^n$$
To Bryan and any other visitors reading this topic, I encourage you to post other questions of this type in our http://www.mathhelpboards.com/f15/ forum.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
