Building a Quadcopter - Calculate Arm Length
In summary: Multicopters are not really as aerodynamic as other UAVs, but they do have a few advantages. They're cheaper to build, and you don't need as much stability control in the air. They're also easier to fly.
Monsterboy
303
96
Hi ,
I am building a Quadcopter ,i am not sure how to decide(or calculate) the length of the 4 arms .I know that it depends on the propeller size ,i am not sure if any other parameters are involved ,is there any formula to find the length using the parameter(s)?
There is no magic formula.
Longer arms will be heavier, but they do make it easier for a human to control the tilt.
I don't know much about quadcopters, but I would think they would need on-board stability control, in addition to the outside human input. Some sort of gyro-to-motor feedback stabilization...
Is there any way to calculate the maximum speed of a Quadcopter theoretically? I know i can get the speed using the GPS system but is it possible to calculate it? can i get any links to some papers or something?
How big of a copter are we talking?
Ya know, aerospace engineering really is rocket science; it really is that hard!
noagname said:
You'll have to do a lot of searching on google, you can get started here: http://andrew.gibiansky.com/downloads/pdf/Quadcopter Dynamics, Simulation, and Control.pdf
Personally, I wouldn't recommend making a quadcopter from scratch but instead buying a kit and slowly make adjustments as you get a better understand of it.
Yea i bought a kit and built one but now i want build one on my own ,i trying to get a bit less of a hobbyist and a bit more technical(upto my capacity)
Multicopters are not really as aerodynamic as other UAVs ,i don't know how measure the drag forces and stuff.
i am talking about a quadcopter that is 1.5 feet in motor to motor distance(along the diagonal).
Other than simpler mechanical design and cost savings are there any other advantages of quadcopters over other UAVs? i read that helicopters are more stable as they don't need electronic stabilization which is required by quadcopter.
Monsterboy said:
I read that helicopters are more stable as they don't need electronic stabilization which is required by quadcopter.
MOdel helicopters can use a fly-bar to stabilize pitch and roll, but there's a transition to electronic stabilization via 3d gyros called "fly-barless".
http://brage.bibsys.no/xmlui/handle/11250/136686
I have doubt in the rotation matrices part ,i don't know much about.
2.2 Rotation Matrix
To make a dynamic model, the forces and moments acting on the quadcopter must be found. The forces
must also be oriented so they influence the quadcopter in the correct way, no mater how quadcopter is
oriented. Gravity will always point the Z-direction of the navigation frame, but will have vector components
referred to the quadcopter dependent of its orientation. A vector can be oriented to any position with three
successive rotations. In order to overcome the gravity vector the quadcopter's orientation must be rotated,
but not in the physical way, to determine how much force the motors has to put out to keep it hoovering.
The rotations can be done one at a time.
I don't what they mean by 'overcoming gravity vector by rotating the orientation ,not in a physical way!'can someone please explain?
Think of the quadcopter as a disk that can rotate in the plane, about it's axis. That disk can also be tilted by varying the balance of power between opposing motors. The orientation of the disk is important because it decides which motor combination needs power adjustment to navigate in a particular geographical direction. The quadcopter does not have to physically rotate to fly off in a different direction, it only needs to multiply it's orientation by the needed heading direction to decide which motors to adjust in power.
Any tilt from the horizontal will require an increase in thrust to maintain the magnitude of the vertical component that counters gravity. That can be computed by rotation of the orientation vector without physical rotation of the quadcopter.
Judging from the abstract, I think they could explain it better in Norweedish than in Broken English. (I didn't read the full paper).
The only limit to the length of the arms is your money, nothing more...on youtube you can find multirotors carrying people, so...
Related to Building a Quadcopter - Calculate Arm Length
1. What is the purpose of calculating arm length when building a quadcopter?
Calculating arm length is crucial in determining the stability and maneuverability of a quadcopter. It helps in achieving the desired center of gravity and weight distribution, which are important factors for flight control and performance.
2. How do I calculate the ideal arm length for my quadcopter?
The ideal arm length can be calculated by considering the weight of the quadcopter, the size and type of motors used, and the desired flight characteristics. There are also online calculators and software programs available that can help with the calculation process.
3. Is arm length the only factor that affects the flight characteristics of a quadcopter?
No, arm length is just one of the many factors that can affect the flight characteristics of a quadcopter. Other factors include motor size and type, propeller size and pitch, and the overall weight distribution of the quadcopter.
4. Can I adjust the arm length after building the quadcopter?
It is possible to adjust the arm length after building the quadcopter, but it may require significant modifications and repositioning of other components. It is best to determine the ideal arm length before building the quadcopter to avoid any additional work.
5. Are there any safety precautions to consider when determining the arm length of a quadcopter?
Yes, it is important to ensure that the length of the arms is not too long, as it can make the quadcopter unstable and increase the risk of crashes. It is also important to use high-quality materials for the arms to ensure they can withstand the weight and stress of the quadcopter during flight.
  • Mechanical Engineering
  • Aerospace Engineering
