Building an atmospheric chamber
In summary, the conversation discusses the process of building an atmospheric chamber for atmospheric pressure tests. The chamber will be made out of 3/4" plywood with cross-braces for reinforcement. A wet/dry shop vac with a rating of 170 CFM will be used to pull the necessary vacuum. The chamber will also have a vent to control the pressure inside. However, using plywood may not be ideal as it has porosity issues. The shop vac may also not be sufficient for creating a vacuum in a sealed container. Proper design work and a more powerful motor may be necessary for the project.
mtrip
Building an "atmospheric chamber"
I have to build a chamber (ok, large box) to do some atmospheric pressure tests. The box will be 48 inches square. I have to simulate going from sea level (0 feet, 14.696 psia) to 7000 feet (11.34 psia). I'm thinking of building the "box" from 3/4" plywood reinforced with cross-braces (if need be). I've looked at "wet/dry shop vacs" and think one of these might be able to pull the "vacuum" needed. The box is 64 cubic feet and the shop vac can pull 170CFM.
The box will have a vent on it to make it "leaky" to control the pressure inside (I'm thinking the vacuum can suck while the vent can leak letting in air). This way I can control the pressure without resorting to flapper valves or the like. It should also prevent the shop vac getting into a "clogged inlet" and racing the motor.
Does this sound reasonable? I've been looking to find the way to calculate all this but haven't found a reference yet.
Thanks.
Just my take(I'm no expert):
Plywood is not a good choice. It has porosity issues. Gases can leak through, especially during pressure differential.
The shop vac rated at 170 CFM draw assumes relatively non-vacuum conditions. That is, the CFM for a store-bought shop vac will substantially reduce VERY quickly in drawing air out of a sealed container.
Just some basic thoughts...
Forget trying to make this from wood.
Supppose your 64 cu ft box is a 4 ft cube. The area of each face is 16 sq ft = 2300 sq in.
A pressure difference of 14.7 - 11.3 = 3.4 psi will give you a total force on each face of 2300 x 3.4 = 7800 lb which is about 3.5 tons.
If you really want to build this, you need to do some proper design work on it, not something "reinforced by cross braces if need be".
I agree with the calculations of AlephZero.
Plus, concerning air pump requirement, the power needed is the airflow times the pressure differential.
With the appropriate unit conversion:
Power = 170 CFM X 3.4 psi X 3.254 = 1880 W = 2.5 hp
This is without accounting for inefficiencies (motor, pump, duct restrictions, etc.). That power is related to the concept of "http://en.wikipedia.org/wiki/Airwatt" ". You will need a motor a lot more powerful than that.
You will have to consider that power when selecting your controlled «leakage».
Building an atmospheric chamber for atmospheric pressure testing can be a complex process, but it sounds like you have a good plan in place. Using 3/4" plywood reinforced with cross-braces should provide a sturdy structure for your chamber. The use of a wet/dry shop vac to create the necessary vacuum is a clever idea, and the 170 CFM should be sufficient for your 64 cubic feet chamber.
In terms of controlling the pressure inside the chamber, using a vent to make it "leaky" is a practical solution. It will allow you to adjust the pressure without the need for additional equipment such as flapper valves. It is important to ensure that the vent is properly sized to maintain a consistent pressure and prevent the shop vac from getting clogged.
Calculating the exact parameters for your atmospheric chamber can be challenging, and it may require some trial and error. It is recommended to consult with a pressure specialist or refer to established guidelines for atmospheric pressure testing to ensure accurate results.
Overall, your plan for building an atmospheric chamber seems reasonable and well thought out. With proper precautions and calculations, you should be able to successfully simulate different altitudes for your testing purposes. Good luck with your project!
FAQ: Building an atmospheric chamber
1. What is an atmospheric chamber?
An atmospheric chamber, also known as a controlled environment chamber or environmental chamber, is a closed container used to simulate and control various environmental conditions such as temperature, humidity, and gas composition. It is commonly used in scientific research and testing to study the effects of different environmental factors on living organisms, materials, and systems.
2. What are the benefits of using an atmospheric chamber?
The use of an atmospheric chamber allows for precise control of environmental conditions, which is essential for conducting accurate and repeatable experiments. It also provides a safe and controlled environment for sensitive materials and organisms, minimizes external interference, and reduces the risk of contamination.
3. How does an atmospheric chamber work?
An atmospheric chamber typically consists of a sealed chamber, a control system, and sensors to monitor and regulate environmental conditions. The control system uses various mechanisms such as heaters, coolers, humidifiers, and dehumidifiers to adjust temperature, humidity, and gas composition inside the chamber according to the desired settings.
4. What are some common applications of atmospheric chambers?
Atmospheric chambers have a wide range of applications, including biological and medical research, pharmaceutical development, materials testing, and environmental studies. They are also used in industries such as food processing, electronics, and aerospace for quality control and product development.
5. Are there any safety precautions to consider when using an atmospheric chamber?
Yes, there are several safety precautions to take when using an atmospheric chamber. It is essential to follow the manufacturer's instructions for proper operation and maintenance. Additionally, users should be aware of potential hazards such as high or low temperatures, humidity, and gas concentrations and take appropriate safety measures, including proper training and protective gear.
