Building an ice rink - question about water pressure exerted on a wall
In summary, Roger is thinking that adding a ramp of filler may help to reduce the pressure exerted on the wall by the water.
schiavonir
Hi physics folks-
Every year for the past 3 years, I have built an ice rink in my back yard. Unfortunately, I do not have the flattest back yard, in fact it has quite a downward slope and then a steep uphill slope. But, I'm determined the make the biggest rink I can reasonably make, given what I have to work with.
So, the challenge I end up with is that the side that is furthest downhill ends up being about 30" high, with the pressure of several thousand gallons of water pushing on that wall. It is a struggle, all winter long (and one I sometimes lose) to keep that wall up. I have tried building various bracing structures, and this year I've pounded 2x4 stakes into the ground at 6 different points along that side, and I'm going to build 45 degree supports in addition. I have one more idea, and this idea is what brings me here.
My thought is to add a "ramp" of filler up against that wall in such a way that I create something of a bowl instead of a vertical dam. This would have the benefit of a) using less water, which therefore means less water will be exerting pressure on the wall, and b) exerting pressure downward on the filler material instead of on the wall. Here is an attempt to diagram it.
This diagram represents previous years:
G = ground
W = wall
* = water
X = filler
_________W
*********W
*********W
*********W
*********W
*********W
GGGGGGGGGGGGGGG
This diagram represents my idea to add filler:
_________W
*********W
********XW
******XXXW
*****XXXXW
***XXXXXXW
GGGGGGGGGGGGGGG
So will adding filler up against the wall help to reduce the force exerted on the wall by the water?
Thanks in advance for your help. I am an engineer myself, but in Computer Science, and it's been a long time since I've taken those physics classes where I would be able to calculate something like this myself. Let me know if anything in my explanation is unclear.
-Roger
Just a humble physics student here, but perhaps I can help get the discussion started. In the simple case of a completely level rink, the pressure per unit area on your wall is simply [tex] P = \rho g y [/tex], where rho is the density of water, g is the gravitational acceleration, and y is the depth of the rink. In that case, your solution would be very effective, because you're adding strength to the wall proportionally to the increase in pressure.
The problem I see is that when the rink is titled at an angle, you're now dealing with a two-dimensional problem. There is going to be the pressure component caused by the water in the y direction (vertically), but there is also going to be an x component (horizontally) proportional to the severity of the incline and the length of the rink in that direction. Then, referenced to the lower end of the rink, the pressure equation would become something like [tex]\rho g(ycos(\theta) + x sin(\theta))[/tex] where theta is the angle of the incline with respect to the horizontal. In that case the horizontal component is exerting all its pressure evenly across the wall, so I don't believe the ramp of filler will help for that component. Basically the wall will have to be thick enough from top to bottom to support that component of the force.
If the slope is totally unavoidable, my intuition would be to use the ramp of filler on the inside to handle the first part of the force, and then brace the upper part of the wall from the outside, where it is weakest with respect to the second component of the force.
I maybe I’m missing something but it sounds to me digging down 30 inches on the high side of the hill might be the answer. It would use a lot less water and you would not have the support problem. I don’t know you’re exact situation and this may not be possible.
Related to Building an ice rink - question about water pressure exerted on a wall
1. How does water pressure affect the structural stability of an ice rink wall?
The weight and pressure of the water used to create an ice rink can exert a significant force on the walls, especially if the water freezes and expands. This can put strain on the wall and potentially cause it to crack or collapse.
2. What can be done to prevent the water pressure from damaging the ice rink walls?
To prevent damage from water pressure, the walls of an ice rink are typically reinforced with strong materials such as steel or concrete. The walls may also be designed with sloped sides to distribute the force of the water more evenly.
3. How is the water pressure measured in an ice rink?
The water pressure in an ice rink is typically measured in pounds per square inch (psi). This can be done using specialized equipment such as pressure gauges or sensors.
4. Can changes in temperature affect the water pressure in an ice rink?
Yes, changes in temperature can affect the water pressure in an ice rink. As water freezes and expands, it can increase the pressure on the walls. Similarly, as the ice melts and contracts, the pressure may decrease. It is important to monitor and adjust for these changes to maintain the structural integrity of the walls.
5. Are there any safety precautions that should be taken to account for water pressure in an ice rink?
Yes, it is important to regularly inspect and maintain the walls of an ice rink to ensure they can withstand the water pressure. It is also recommended to have emergency protocols in place in case of a sudden increase in water pressure or wall damage.
  • Other Physics Topics
  • Mechanics
  • Classical Physics
  • General Engineering
18K
