Bulb Temperature using resistance
In summary, the incandescent bulb has a resistance of 12 ohms when at room temperature and 400 ohms when hot and delivering light to the room. The temperature coefficient of resistivity, alpha, is 0.008 degrees Celsius^-1 and the base resistance, R0, is determined at 0 degrees Celsius. The temperature of the bulb when in use can be calculated using the equation T = T0 + (1/alpha)[(R/R0)-1], which gives a value of 25.25866 degrees Celsius. However, there was an error in the original calculation as 1/alpha should not be used, instead the value of alpha (0
hoseA
61
An incandescent bulb has a resistance of 12 *omega
when it is at room temperature (25 degrees C) and
400 omega * when it is hot and delivering light to
the room. The temperature coefficient of re-
sistivity of the filament is 0.008 (degrees C)^-1, where
the base resistance R0 is determined at 0 degrees C.
What is the temperature of the bulb when
in use? Answer in units of degrees C.
= 25 + (1/{1/.008})[(400/12)-1]
=25.25866 deg. C
This is wrong. What've I blundered this time?
Help is most appreciated.
Firstly could you verify the units for that resistivity coefficient? It is far too low to be reasonable in my opinion. The equations you need to set up from the word problem should look like:
[tex]R(25 C) = 12 \Omega [/tex]
[tex]R(T_1) = 400 \Omega [/tex]
[tex]R(T) = (R_0 + kT) \Omega [/tex]
where T1 is the temperature of the bulb when in use, and k is the resistivity coefficient. See if these equations make sense with regard to the word problem.
0.008 degC^-1 is alpha ... its not 1/alpha ... that's what is wrong...
1/alpha will have the unit deg celsius. only then you can add it with T0 ..
What you have taken as alpha is actually 1/0.008 degC^-1 ... so your 1/alpha will have the units degC^-1 so you cannot add it to [tex]T_{0}[/tex]
In a nutshell, change that thing to 0.008... you'll get the answer which seems to be correct.
And by the way, the value for the coefficent of resistivity isn't that low...Actually, its value for nichrome is 0.0004 per deg celsius and we know that nichrome materials are used as heating elements in many appliances ...
FAQ: Bulb Temperature using resistance
FAQs about Bulb Temperature using resistance
1. What is bulb temperature using resistance?
Bulb temperature using resistance is a method of measuring the temperature of a bulb or other object by measuring the change in resistance of a material as it is heated or cooled.
2. How does it work?
The resistance of a material changes as its temperature changes. By measuring the resistance of a material and using a conversion formula, the temperature of the material can be calculated.
3. What materials can be used for this method?
Any material that exhibits a change in resistance with temperature can be used for this method. Some common materials include platinum, nickel, and copper.
4. What are the advantages of using this method?
This method is relatively simple and low cost compared to other methods of temperature measurement. It also does not require direct contact with the object being measured, making it useful for measuring the temperature of delicate objects or in hazardous environments.
5. Are there any limitations to using this method?
One limitation is that the accuracy of the measurement depends on the material being used and the conversion formula. Additionally, the resistance of the material may also be affected by factors other than temperature, such as humidity or pressure.
