How to Calculate Bullet Velocity After Penetrating a Block
In summary, the conversation discusses the conservation of momentum and kinetic energy in a collision between a bullet and a block on a rough surface. The velocity of the bullet can be calculated using the conservation of momentum, while the velocity of the block can be calculated using the frictional force. The kinetic energy lost during the collision can also be calculated, but it is not necessary for solving the problem.
domingoleung
Block 1 (6 kg) is initially at rest on a rough and horizontal surface with coefficient of kinetic friction μk = 0.4. A bullet (0.05 kg) initially moving at speed u = 854 ms-1 firstly penetrates through block 1 which travels 0.1 m and comes to rest. Assume that there is no air resistance. Find the speed of the bullet vbu just after penetrating through block 1
Conservation of Momentum
Change in KE = Change in thermal energy
0.5 * (6)* vblock^2 = 0.4 * 6 * 9.81* 0.1
vblock = 0.885
By Conservation of Momentum,
(0.05)(854) = (0.05)*vbu + (6)(0.885)I am not sure whether Change in KE = Change in thermal energy is true coz there should be a change in internal energy of the block and the collision is not elastic
domingoleung said:
Homework Statement:: Block 1 (6 kg) is initially at rest on a rough and horizontal surface with coefficient of kinetic friction μk = 0.4. A bullet (0.05 kg) initially moving at speed u = 854 ms-1 firstly penetrates through block 1 which travels 0.1 m and comes to rest. Assume that there is no air resistance. Find the speed of the bullet vbu just after penetrating through block 1
Relevant Equations:: Conservation of Momentum
vblock = 0.885
You need to include units in those numbers. What you have done so far looks about right. Why don't you finish things off?
Yea thanks for reminding me. Vbu should be 747.8 m/s then :)
Yes, although that's probably at least one significant figure too many.
Well, I don't quite understand why Δ KE equals to Δ Eth
Could you explain a bit?
You know that momentum is conserved in the (nearly) instantaneous collision. The velocity of the block immediately after the collision tells you the velocity of the bullet immediately after the collision (which is what you want to calculate). And what you did calculate!
The velocity of the block after the collision can be calculated by how long it takes to stop under a known frictional force. Which, again, is what you did.
The last piece of the equation is the KE lost during the collision. You are not asked to calculate that, but you can if you want, using the velocities you have calculated.
The common theme in these problems is to use conservation of momentum but not conservation of kinetic energy. In general, you don't know how much kinetic energy was lost until you have completed the other calculations.
Likes domingoleung and jim mcnamara
Thanks! <3 <3 <3
Related to How to Calculate Bullet Velocity After Penetrating a Block
1. How does the velocity of the bullet affect its ability to penetrate a block?
The velocity of a bullet is a key factor in its ability to penetrate a block. The higher the velocity, the more kinetic energy the bullet has, which allows it to overcome the resistance of the block and penetrate deeper.
2. What type of material is best for a block to stop a bullet?
The best material for a block to stop a bullet depends on the type of bullet being used. Generally, dense and strong materials such as steel or titanium are effective in stopping high-velocity bullets, while softer materials like wood or sandbags are better for slower bullets.
3. Can the angle of impact affect a bullet's ability to penetrate a block?
Yes, the angle of impact can have a significant impact on a bullet's ability to penetrate a block. A bullet that hits a block at a perpendicular angle is more likely to penetrate deeper than one that hits at an oblique angle.
4. How does the shape of the bullet affect its penetration into a block?
The shape of a bullet plays a crucial role in its ability to penetrate a block. Bullets with pointed tips are more aerodynamic and can penetrate deeper, while flat or rounded bullets may deform upon impact and lose their ability to penetrate as deeply.
5. Is there a limit to how thick a block can be before a bullet cannot penetrate it?
There is no specific limit to how thick a block can be before a bullet cannot penetrate it, as it depends on various factors such as the velocity and type of bullet, as well as the material and density of the block. However, as the thickness of the block increases, the likelihood of a bullet penetrating it decreases.
