Bunch of questions that may have typographical errors in the answer key
  • Thread starter BSElectrician
  • Tags
    Errors
In summary: A_{1} = \frac{1}{2}absin{\theta} A_{1} = \frac{1}{2}(25)(35)sin(82) A_{1} = 433.247Law of cosine for the opposite side: o = opposite sideo = \sqrt{35^2 + 25^2 - 2(25)(35)\cos{82}}o = 40.1opposite angle of 82 degrees360 - 90 - 90 - 82 = 98 degreesangles of the second triangle are 98/2 = 41 since they have both 90 degrees anglehence they also have the congruent
BSElectrician
I have a problem that involves these questions, what i need you to do is to verify if the textbook answers are typographical errors. Ill show my solutions and have to tell me which part i get wrong.
1. A corner lot is 35m on one street and 25m on the other street. The angle between the two lines of the street being 82 degrees. The other to two lines of the lot are respectively perpendicular to the lines of the streets. What is the worth of the lot if its unit price is $2500 per square m?
textbook Ans. 1,884,050
2. Find the distance between (5, 30degrees) and (-8, 50 degrees).
Ans. 10.14
3. The angle from line 1 to line 2 is arctan(2/3) and the slope of line 1 is -1. Find the slope of line 2.
Ans. -1/5
4. the sides of a cyclic quadrilateral measures 8cm, 9cm, 12cm and 7cm. Find the area of the circumscribing circle
Ans. 134.37 cm^2
5. How far from a vertex is the opposite face of a tetrahedron if an edge is 50cm long?
Ans: 40.825cm
1. I will subdivide the total lot into 2 triangles so i can calculate the area
[itex]A_{1} = \frac{1}{2}absin{\theta} [/itex]
[itex]A_{1} = \frac{1}{2}(25)(35)sin(82) [/itex]
[itex]A_{1} = 433.24[/itex]
[itex]o = \sqrt{35^2 + 25^2 - 2(25)(35)\cos{82}}[/itex]
[itex]o = 40.1[/itex]
hence they also have the congruent sides
law of sine to find distance d:
[itex]\frac{\sin(98)}{40.1} = \frac{\sin(41)}{d}[/itex]
[itex]d = 26.5665[/itex]
[itex]A_{2} = \frac{1}{2}(26.5665)^{2}\sin{98} [/itex]
[itex]A_{2} = 349.455[/itex]
[itex]A_{T} = A_{1} + A_{2} = 782.695 sq.m [/itex]
[itex]Cost_{total} = 782.695(2500) = 1,956,743.613[/itex]
Ans. 1,956,743.613 dollars
2.
5 in the 1st quadrant
8 in the 3rd quadrant
Angle between the two sides = 90 + 30 + 40 = 160
Law of cosine
[itex]d^2 = 5^2 + 8^2 -2(5)(8)\cos(160)[/itex]
[itex]d = 12.81[/itex]
Ans. 12.81
3.
Formula
[itex]\theta = \frac{m_{2} - m_{1}}{1+m_{2}m_{1}}[/itex]
since:
[itex]\tan^{-1}(\frac{2}{3}) = \frac{m_{2} - (-1)}{1+m_{2}(-1)}[/itex]
Ans. [itex]m_{2} = -0.26[/itex]
4.
Area of cyclic Quadrilateral
[itex]A_{cyc} = \sqrt{(s-a)(s-b)(s-c)(s-d)}[/itex]
where
[itex]s = \frac{a + b + c + d}{2} [/itex]
and the radius of the circumscribing circel
[itex]r = \frac{\sqrt{(ab+cd)(ac+bd)(ad+bc)}}{4A_{cyc}}[/itex]
[itex]s = \frac{9 + 8 + 7 + 12}{2} [/itex]
[itex]s = 18 [/itex]
[itex]A_{cyc} = \sqrt{ (18-9)(18-8)(18-7)(18-12) }[/itex]
[itex]A_{cyc} = 69.714[/itex]
[itex]r = \frac{\sqrt{((9)(8)+(7)(12))(9(7)+8(12))(9(12)+8(7))}}{4(69.714)}[/itex]
[itex]r = 7.233[/itex]
[itex]A_{circ} = \pi{7.233}^2[/itex]
Ans. [itex]A_{circ} = 164.37[/itex]
5.
A tetrahedron is a triangular shaped object with equal sides
So i will assume that the shortest distance will be from the central side of the face to the angle bisector opposite to that face.
Then on the side view of the tetrahedron we have a equilateral triangle
i cut the triangle in half so that halved triangle has angles 30,60,90 and d is distance from vertex to face
[itex]\sin(\theta) = \frac{opposite}{hypotenuse}[/itex]
[itex]\sin(60) = \frac{d}{50} [/itex]
Ans. d = 43.30cm
Q1) $1,833,997
Q2) 12.8131
Q3) -0.2
m1 is -45 deg, diff is 33.69 deg, so m2 is -11.31 deg.
tan -11.31 is -0.2
That should be 180° - 98° = 82°, and 82°/2 = 41°. However, those two angles are not congruent !
This is clear because the two unknown angles of the first triangle can't possibly be congruent. Use the law of sines to find these two angles.
38.1465° and 59.8535° in your first triangle.
Q4) 134.4
Q5) 40.82483cm
(First draw the triangle that cuts the tetrahedron in half by cleaving one edge and bisecting two faces, then drop a perpendicular from a vertex).
Related to Bunch of questions that may have typographical errors in the answer key
1. What should I do if I notice a typographical error in the answer key?
If you notice a typographical error in the answer key, you should first double-check your answer and make sure it is correct. If you still believe there is an error, you should reach out to the author or publisher of the answer key to inform them of the mistake.
2. How common are typographical errors in answer keys?
Typographical errors in answer keys are not uncommon, but they should be minimized as much as possible. It is important for authors and publishers to thoroughly proofread and edit their answer keys before publication to reduce the likelihood of errors.
3. Can typographical errors in answer keys affect my test score?
If a typographical error in the answer key causes an incorrect answer to be marked as correct, it could potentially affect your test score. However, if the error is minor and does not significantly impact the overall test, it is unlikely to have a major impact on your score.
4. How can I avoid making mistakes on tests due to typographical errors in answer keys?
The best way to avoid being affected by typographical errors in answer keys is to thoroughly review and understand the material being tested. This will allow you to catch any incorrect answers caused by errors in the answer key and choose the correct answer based on your understanding of the subject matter.
5. Is it possible for an answer key to have multiple typographical errors?
Yes, it is possible for an answer key to have multiple typographical errors. This is why it is important for authors and publishers to carefully proofread and edit their answer keys before publication to minimize the chances of multiple errors. As a test-taker, it is also important to carefully review your answers and double-check them against the material being tested to catch any potential errors.
  • Linear and Abstract Algebra
