Bundle of energy, but does it have mass?
  • Thread starter myrhinobutt2
  • Tags
    Energy Mass
In summary, a photon is a bundle of energy that does not have mass but has momentum. It can be related to energy through E = hf, with h being the Plank's constant and f being the frequency. It exhibits both particle and wave properties, with the latter being more commonly known.
myrhinobutt2
This is a two part question. First question: what exactly is a photon? I know that it's essentially a bundle of energy, but does it have mass? Can it be related by E=mC^2?
Second question: If I were to find a perfectly smooth spherical mirror (also assuming the distance between atoms is sufficiently small that the light cannot escape) and somehow turn on a light inside, would the photons somehow build up and become jammed in there?
Photons don't have mass but they have momentum. You don't write
E =mc^2 for a photon but you write E = h f , h being the Plank's constant and f being the frequency.
Photon, simply put, is the quantization of electromagnetic energy. Depending on the context, we could observe particle properties of photons (Compton scattering, photoelectric effect) or the more natural classical wave properties. People had been familiar more with the latter by the time it was discovered so photoelectric effect and Compton were quite a shock.
I can provide the following response to these questions:
Firstly, a photon can be described as a fundamental particle of light and electromagnetic radiation. It is considered to be the smallest unit of light and carries a specific amount of energy. However, unlike other particles such as electrons or protons, photons do not have mass. This is because they are not made up of any subatomic particles and instead, they are considered to be massless.
In terms of the famous equation E=mc^2, it cannot directly be applied to photons as they do not have mass. This equation specifically relates to the energy and mass of a massive object, while photons do not fall under this category. However, the energy of a photon can be related to its frequency and wavelength through the equation E=hf, where h is Planck's constant and f is the frequency of the photon.
As for the second question, if you were to place a light source inside a perfectly smooth spherical mirror, the photons would not become jammed or trapped. Photons are constantly moving at the speed of light and do not interact with each other in a way that would cause them to accumulate or get stuck in one place. They would simply continue to bounce off the mirror's surface and reflect outwards, creating an endless cycle of reflection.
I hope this explanation helps clarify the concept of photons and their properties. it is important to understand the fundamental aspects of particles and their behaviors in order to further our understanding of the world around us.
FAQ: Bundle of energy, but does it have mass?
What is a bundle of energy?
A bundle of energy refers to a collection of energy that is typically associated with a specific physical object or system. It can manifest in various forms such as light, heat, or motion.
Is energy the same as mass?
No, energy and mass are two distinct concepts in physics. Energy is the ability to do work, while mass is a measure of the amount of matter in an object. However, according to Einstein's famous equation E=mc², mass and energy are equivalent and can be converted into each other.
How can something have energy but no mass?
According to the theory of relativity, objects can have energy without necessarily having mass. This is the case for particles with zero rest mass, such as photons, which carry energy through electromagnetic radiation.
Can energy be created or destroyed?
According to the law of conservation of energy, energy cannot be created or destroyed, only transferred from one form to another. This means that the total amount of energy in the universe remains constant.
How is energy measured?
Energy is measured in joules (J), which is a unit of energy equivalent to the amount of work done by a force of one newton over a distance of one meter. Other common units of energy include calories and kilowatt-hours (kWh).
