Bungee Jump: Conservation of Energy
In summary, the bungee cord of an elastic bungee jumper with mass m and natural length L, and stiffness k is stretched by an amount x=mg/k(1+√(1+(2kl/mg))) at the lowest point of the fall. This is deduced using the equations F=-kx and PE=mgh=0.5kx^2, with the height h=L+x and the total energy before and after the jump being equal. The final equation is quadratic and needs to be solved to get the desired form.
teme92
185
A bungee jumper of mass m drops o ff a bridge and falls vertically downwards. The bungee cord is elastic with natural length L and stiff ness k. Deduce that at the lowest point of the fall, the cord is stretched by an amount:
F=-kx
PE=mgh=0.5kx2
Where h=L+x
The total energy before the jump is equal to the total energy after the jump. Since at the bottom there is no kinetic energy I said the Potential Energy before is equal to the Elastic Energy at the bottom.
So:
mg(L+x)=0.5kx2
x2=(2mgx +2mgl)/k
x=√((2mgx +2mgl)/k)
I'm having problems here trying to get in the asked form. Have I forgotten something n the conservation of energy?
There's an x on the right hand side of the equals sign in your final answer.
The line above that is a quadratic equation.
So does that mean I have to solve it quadratically?
I suppose you know how to solve a quadratic equation. ax^2 + bx + c = 0 ?
I would like to point out that the equations used in this solution are not entirely accurate. The correct equation for elastic potential energy is PE=0.5kx^2, not 0.5kx2. Additionally, the equation for potential energy is mgh, not mgh=0.5kx2.
To solve the problem, we can use the conservation of energy principle, which states that the total energy before and after the jump must be equal. At the start of the jump, the total energy is solely in the form of gravitational potential energy (mgh), since the jumper has not yet fallen. At the bottom of the fall, the total energy is in the form of both gravitational potential energy (mgh) and elastic potential energy (0.5kx^2).
Using the conservation of energy principle, we can set these two equations equal to each other:
mgh=0.5kx^2
Since h=L+x, we can rearrange the equation to solve for x:
x=√(2mgh/k)
Substituting in the value of h, we get:
x=√(2mg(L+x)/k)
Solving for x, we get:
This is the same result as the one provided in the homework statement. It is important to note that the conservation of energy principle is based on the assumption that there is no external work done on the system. In reality, there may be slight variations in the final stretched length of the bungee cord due to factors such as air resistance. However, this equation provides a good approximation of the stretched length of the bungee cord at the bottom of the fall.
Related to Bungee Jump: Conservation of Energy
1. How does the conservation of energy apply to bungee jumping?
The conservation of energy states that energy cannot be created or destroyed, only transferred from one form to another. In bungee jumping, the potential energy of the jumper at the top of the jump is converted into kinetic energy as they fall, and then back into potential energy as they rebound. This process continues until all of the energy is dissipated through friction and other forces.
2. What type of energy is involved in a bungee jump?
In a bungee jump, the primary types of energy involved are potential and kinetic energy. Potential energy is stored in the jumper's body when they are at the top of the jump, and kinetic energy is generated as they fall and accelerate towards the ground.
3. Does the height of the bungee jump affect the conservation of energy?
Yes, the height of the bungee jump does affect the conservation of energy. The higher the jump, the more potential energy the jumper will have at the top, which will result in a faster fall and higher speed at the bottom. This means that a higher jump will require more energy to be dissipated, leading to a more intense experience for the jumper.
4. How does the elasticity of the bungee cord impact the conservation of energy?
The elasticity of the bungee cord plays a crucial role in the conservation of energy during a bungee jump. When the jumper reaches the end of the cord, the potential energy is converted into elastic potential energy in the cord, causing it to stretch and slow down the jumper's descent. This allows for the energy to be gradually dissipated and prevents the jumper from hitting the ground with a large amount of force.
5. Is the conservation of energy the only safety consideration in bungee jumping?
No, the conservation of energy is not the only safety consideration in bungee jumping. Other factors, such as the strength and quality of the bungee cord, proper equipment and rigging, and trained staff, are also crucial for a safe and successful jump. It is essential to follow all safety protocols and guidelines to minimize the risk of injury during a bungee jump.
