Bungee Jumper/Oscillatory Motion
In summary, Larry was found dead at the 7th floor of a building with a mass of 90kg. When the bungee cord is cut, it has a relaxed length of 5 stories. When the detective tries to solve the murder, they are stuck because they do not know the height of the person at the time of the death, nor do they know the potential energy of the situation. They use kinematics to find the lowest point of the bungee, which is 35m off the ground. Without knowing the potential energy of the situation, they think that the bungee only stores energy one way and that the person only lands a few meters off the ground.
jromega3
27
A person named Larry is found dead, hanging at the 7-story level of a 15 story (45m) building. Larry has a mass of 90kg. When the bungee cord is cut, it has a relaxed length of 5 stories. Detective say he hit the ground while bungee jumping, you KNOW he was murdered. What is your evidence?
Fs=-Ks (X)
X(t)= Acos(wt + theta)
Fs=Fg when he's resting
So at the 7 story level Fs=Fg if there's no acceleration. That's a change in X of 3 floors, or 9m. 90kg*9.8=9m*Ks
Ks=98N/M.
Know we know W= root (ks/mass), or 98/90, which gives me a w of 1.04
so X=A*cos(1.04T + theta)
I'd assume solving for A, or amplitude, from the resting point (7 floors up) would tell us if he hits the ground or not. If it's 21 or over, he hits it, if it's under, he clearly cannot hit the ground.
But, that's three unknowns.
So, I'm stuck, but just had an idea that I'm not sure is valid or not.
Using simple kinematics, if I were to choose 2 points, (say at 10m above and below the resting point), I could find the Avg. acceleration (Fg-Fspring)/mass, and knowing average acceleration and X position, I could solve for T.
Knowing T for X, I'd have two unknowns (A and theta) for two equations. I could then solve for A.
Would this be a correct line of thinking? Or am I erring somewhere? Thanks
Did you think about using conservation of energy? What energies are involved in this problem?
How about using energy conservation?
EDIT: turin beat me to it.
Ahh. The initial total Energy would be just
mgh + PEs, right?
Now what? Find what mgh + PEs works on the other side to equal the same total energy, and this would be the lowest point (where V=0). If so, that makes sense. Thanks...hopefully I'm on the right track ;)
Well, doing this, I got X to be 35m off the ground...hmm.
That doesn't seem right, since it puts Larry at about the 12th floor, above where he was found, and above the relaxed position of the bungee.
Perhaps you could say what value you got for the total initial energy, and also what equation did you set up to find the height? That would help us find where the error is.
Yeah, I definitely erred somewhere along the road.
So the initial energy was mgh + 0.5Ks(delta x)^2
90*9.8*45 + 0.5*98*15^2 = 50,715 J
now to solve for x (lowest point, ie where all energy is potential)...50,715=90*9.8*X + 0.5*98*(x-15)^2
s0 50,715=882X + 49(-30x+225+X^2)
0=49X^2 + 588X -39690
X=-23.1, 35.1
35.1 is the only possible solution of the two...but that's obviously wrong.
Ah. The bungee does not contribute to the potential energy at the top of the building, and it does not compress, so it only effectively stores energy one way (by stretching). It only starts to stretch at a particular floor, and that should be your zero point for the elastic potential energy. Otherwise, your approach looks good. (I did not read all of your algebra - this text based stuff is sure annoying.)
Yep. That would've been my problem. Without that he "lands" a few meters off the ground. Thanks for the help everyone
Related to Bungee Jumper/Oscillatory Motion
1. What is bungee jumping?
Bungee jumping is an extreme sport that involves jumping from a tall structure, such as a bridge or a crane, while attached to a long elastic cord. This cord is designed to stretch and recoil, allowing the jumper to experience a thrilling free fall before being safely pulled back up.
2. How does bungee jumping use oscillatory motion?
Bungee jumping uses oscillatory motion in the form of a harmonic oscillator, which is the elastic cord that the jumper is attached to. As the jumper falls, the cord stretches and stores potential energy. When the cord reaches its maximum stretch, it begins to recoil and converts the potential energy into kinetic energy, propelling the jumper back up.
3. Is bungee jumping safe?
When performed correctly, bungee jumping is generally considered to be a safe activity. However, like any extreme sport, there are risks involved. It is important to only participate in bungee jumping with a reputable and experienced company, and to follow all safety protocols and equipment checks.
4. What factors affect the oscillatory motion in bungee jumping?
The oscillatory motion in bungee jumping is affected by several factors, including the length and elasticity of the cord, the weight of the jumper, and the height and location of the jump. These factors can impact the speed, duration, and intensity of the oscillatory motion experienced by the jumper.
5. Can anyone bungee jump?
While bungee jumping can be a thrilling experience, it is not suitable for everyone. Individuals with certain medical conditions, such as heart problems or back injuries, should consult with their doctor before attempting a bungee jump. Additionally, most bungee jumping companies have age and weight restrictions for safety reasons.
15K
