Buoy in waves problem (Feynman)
In summary, the amplitude of a spar buoy's vertical motion is A with respect to the mean ocean surface when there are sinusoidal waves with height h and period T. The equation for the amplitude is mX'' = hApgsin(wt). The amplitude is proportional to the displacement x from equilibrium.
mainguy
Hi all, would appreciate a spot of help on this problem which originally comes from Feynman's introductory physics course.
1. Homework Statement
'A spar buoy of uniform cross-section floats in a vertical position with a length L submerged when there are no waves on the ocean. What is the amplitude A with respect to the mean ocean surface of the vertical motion of the uoy when there are sinusoidal waves of height h (crest to trough) and period T on the ocean? (Neglect fluid friction)
I just went for a simple differential equation, first finding an expression from:
mg = Laρg (a = area of buoy, ρ = density of water)
And rarranged to find p = m/LA
[/B]
Then from a simple differential equation
mX'' = hApgsin(wt)
Found x = hgT2/L4pi2
Where T is period.
Aaand it was wrong. Vaguely close to the real answer but I'm out by a fair bit, no idea what to correct for as there is no frictional term.
mX'' = hApgsin(wt)
Where T is period.
Aaand it was wrong. Vaguely close to the real answer but I'm out by a fair bit, no idea what to correct for as there is no frictional term.[/B]
You need to think a little more...what is the differential equation in the absence of waves?...then add the driving force
In the absence of the wave surely the differential is just the bouyancy take away the weight or:
mx'' = ρLAg - mg
Then when the waves are added L becomes a function of t:
mx'' = ρAg(L + hsin(wt)) - mg
But this just leads down another dead end :/
I feel like I'm missing some fundamental aspect of the physical scenario?
mainguy said:
mx'' = ρLAg - mg
No, you need to consider a displacement x from equilibrium (even without waves).
Likes hutchphd
Thanks, so there is a restoring force proportional to the displacement from equilibrium:
F = -xAρ
Still no idea where to take this
F = -xAρ
You missed the factor g.
You now need to be careful how you define your variables. I would keep x as the displacement from the equilibrium position in flat water, i.e. from a fixed point in space. So you need to express the excess buoyancy at time t, taking the waves into account.
F = -xAρ
Being careful about what you choose to call x=0 put all these net forces into the Newton equation for motion with the wave.. ( Don't forget gravity!) You should recognize the result as an inhomogeneous second order differential eqn (have you seen these?) specifically called a driven harmonic oscillator. This equation is ubiquitous and you should master it inside and out... Incidently this is a very nice problem...
Ah my bad, haha, sorry it was late.
So then the equation looks fairly similar, as x is surely just hsinwt?
So F = - hAρgsin(wt)
If we integrate this a few times w
X = C - hρgsin(wt)/Lω2
X = C - (hgT2/4π2)sin(wt)
But C is 0 as at t = 0 x = 0
So amplitude is just the part out front of sin, right?
Feynman's answer has this part and an additional constant, however I can't see why the constant wouldn't disappear as surely the rod won't oscillate about some new equilibrium :/ :'(
Exactly what is the equation from Newton's law? Write it down.
Oh ok, is it:
mx'' = mg - Bouyant froce
And the bouyant force varies according to sine?
mainguy said:
Oh ok, is it:
Yes the buoyant force will depend upon the difference between the position of the buoy and that of the surface. So write it down (with care about what x=0 is)
Thanks a bunch for guiding me through this, it's really helpful.
So I thought the bouyant force is, taking x as the distance from the starting position where Fb = mg
(L + h - x)*Aρg
Where h = h0sinwt
mx'' = mg - LAρg - hsinwtAρg + xAρg
Then the first two terms cancel as they're equal in equilibrium:
mx'' = xAρg - hsinwtAρg
I feel like I'd need to apply complex numbers/exponential guesses to get this? Still new to differential eqs :/
Careful with signs. Which way are you taking as positive for x? It should be evident that changes in x lead to an opposing acceleration, not a reinforcing one.
There's plenty online on forced oscillations, e.g. https://math.libretexts.org/TextMap...r_ODEs/2.6:_Forced_Oscillations_and_Resonance.
All those I found also allow for damping, but you can just discard that part.
Very good but check your signs. Soon you will know many ways to solve this. The good news is that all the ways are kosher including guessing (as long as it solves every part of the problem). Since you intuit that in steady state this thing will be oscillating with the incident wave try x=constant sinwt and see if you can solve for the constant. Notice the sharp (infinite with no friction) response at the natural "bobbing" frequency of the buoy. If you really understand this system you will understand about 25% of physics... maybe more! Good luck..
Related to Buoy in waves problem (Feynman)
1. How does the buoy in waves problem relate to Feynman's work?
The buoy in waves problem was one of the many examples that physicist Richard Feynman used to illustrate principles of classical mechanics in his famous lectures. It demonstrates the concepts of buoyancy, forces, and oscillations, which are important in understanding the behavior of objects in fluids.
2. Can you explain the physics behind the buoy in waves problem?
The buoy in waves problem involves a buoy floating on the surface of a body of water, which is being disturbed by waves. The buoy experiences forces from the waves, as well as from gravity and buoyancy. These forces cause the buoy to oscillate up and down, with a characteristic frequency determined by the properties of the buoy and the waves.
3. Why is the buoy in waves problem important in oceanography?
The behavior of objects in waves, including buoys, is crucial in understanding ocean currents and circulation patterns. Buoys are often used in oceanographic research to collect data on wave heights and frequencies, which can provide valuable information about the state of the ocean. Understanding the physics behind the buoy in waves problem is essential in interpreting this data.
4. How does the buoy in waves problem relate to real-life situations?
The principles illustrated by the buoy in waves problem can be seen in many real-life situations, such as the motion of boats and ships on the ocean, the behavior of floating objects in a swimming pool, or even the movement of air bubbles in a glass of soda. Understanding these principles can help engineers design more efficient ships and structures that can withstand the forces of waves and other fluid motions.
5. What are some practical applications of the buoy in waves problem?
The buoy in waves problem has practical applications in fields such as naval engineering, oceanography, and fluid dynamics. It is also a useful example for teaching concepts of classical mechanics and oscillations in physics courses. Additionally, the behavior of buoys in waves can be used to predict and monitor the weather and ocean conditions, which is important for industries such as fishing, shipping, and offshore oil and gas operations.
12K
