Buoyancy: Cube of Iron - solved this correctly?
In summary, to solve the problem of creating a hollow cube of iron that will not sink in water, the minimum length of each side should be 3.18 meters. This is determined by calculating the volume of iron and using the equation for buoyancy to find the volume of water displaced by the cube.
snowcrystal42
Hi,
Just wondering if I'm going about solving this problem correctly:
"A block of iron quickly sinks in water, but ships constructed of iron float. A solid cube of iron 1.6 m on each side is made into sheets. From these sheets, to make a hollow cube that will not sink, what should the minimum length of the sides be? (density of iron = 7860 kg/m3)"
Since it's a solid cube of iron, the volume of iron = 1.63 = 4.096 m3
Mass of iron = density of iron x volume
Since the hollow cube is floating, it is under forces mg (weight of the iron) and the buoyant force, which are equal to each other.
mg(iron) = ρ(water) x V(water) x g
g drops out of equation
so V(water) = mg(iron)(water)
V(water) = 32.19 m3
Since the shape is supposed to be a hollow cube, each side length is the cube root of the volume, so each side is (32.19) = 3.18 m
Thanks!
That appears correct.
Related to Buoyancy: Cube of Iron - solved this correctly?
What is buoyancy?
Buoyancy is the upward force exerted by a fluid on an object placed in it. It is caused by the difference in pressure between the top and bottom of the object.
How is buoyancy calculated?
Buoyancy is calculated by multiplying the density of the fluid by the volume of the displaced fluid and by the gravitational acceleration. This is known as Archimedes' principle.
What is the cube of iron experiment?
The cube of iron experiment is a classic physics experiment used to demonstrate the concept of buoyancy. It involves placing a cube of iron in a container of water and measuring the change in water level before and after the cube is submerged.
How was the cube of iron experiment solved correctly?
The cube of iron experiment is solved correctly by accurately measuring the dimensions of the cube, calculating its volume, and using the known density of iron to determine the weight of the cube. The weight of the cube should be equal to the weight of the displaced water, demonstrating the principle of buoyancy.
What are some real-world applications of buoyancy?
Buoyancy is used in many real-world applications, such as ship and submarine design, hot air balloons, and life jackets. It is also an important concept in understanding the behavior of fluids, such as in weather patterns and ocean currents.
