Buoyant Force and what densities to consider?
In summary, when submerging an object in a fluid, the buoyant force can be calculated using the equation FB = ρDF × g ×VDF. However, when dealing with a hot air balloon, the equation changes to FB = (ρin - ρout) × g ×Vobject, where ρin is the density inside the balloon and ρout is the density outside the balloon. This equation relies on the rule that the fluid pressure exerts a net force equal to the weight of the fluid displaced. It is important to note that this equation only works when the entire object is immersed in the fluid.
Ian Baughman
36
So I know
FB = ρDF × g ×VDF
when we submerge an object in a fluid such as water but what if we were talking about a hot air balloon? In this case would it be correct to use
FB = (ρin - ρout) × g ×Vobject?​
Where
ρin = density inside balloon and ρout = density outside balloon.
If this is the case how do we know when to differentiate between the two?
Your two equations appear to be using different definitions for "buoyant force"...
The rule is that the fluid-pressure exerts a net force equal to the weight of the fluid displaced ... if this is bigger than the weight of the object, it rises.
That rule works for all situations... don't bother memorising any specific equation, you already know all the ones you need.
The weight of fluid displaced is ##\rho V g## (V is the volume displaced, and ##\rho## is the density of the fluid)
The weight of the object is ##mg##
... so the net upwards force is ##F=\rho g V - mg##
If all the object is in the fluid, then I can write ##m = \rho_mV## since the volume displaced is the same as the volume of the object
... which gives: ##F = (\rho-\rho_m)gV##
... which only works for the case that the entire object is immersed in the fluid.
FAQ: Buoyant Force and what densities to consider?
1. What is buoyant force?
Buoyant force is the upward force exerted on an object by a fluid (such as water or air) that is equal to the weight of the fluid displaced by the object.
2. How is buoyant force calculated?
Buoyant force is calculated by multiplying the density of the fluid by the volume of the displaced fluid and the acceleration due to gravity (9.8 m/s²).
3. What is the relationship between buoyant force and density?
Buoyant force is directly proportional to the density of the fluid and the volume of the displaced fluid. This means that as the density of the fluid increases, the buoyant force also increases.
4. Can buoyant force act on objects in any fluid?
Yes, buoyant force can act on objects in any fluid, as long as there is a difference in density between the object and the fluid. This includes liquids, gases, and even plasma.
5. How does the density of an object affect its buoyancy?
The density of an object affects its buoyancy by determining whether it will float or sink in a fluid. An object with a lower density than the fluid will float, while an object with a higher density will sink. Objects with equal densities to the fluid will be neutrally buoyant, meaning they will neither sink nor float.
