Buoyant Force at the bottom of a pool?
In summary, Buoyant Force is caused by a difference in water pressure. However, for a cube at the bottom of a pool with no water below it, there would be no buoyant force as there is no fluid exposed to the bottom face. This means that the hypothetical question of "What would you weigh on a scale underwater?" would only be approximately true, as some of the buoyant force from below your feet does not exist in this scenario. The buoyant force ultimately arises from the hydrostatic pressure, so it can only occur on surfaces that are exposed to the fluid. Therefore, a cube with a perfectly dry bottom face would not experience any upward buoyant force. Additionally, the concept of buoyant force can be inadequate in
Nathanael
1,650
246
Apparently, Buoyant Force is caused by a difference in water pressure.
So am I correct in thinking that this means if you have a cube (chosen so that buoyant force does not come from the sides, just from the bottom) at the bottom of a pool, there would be no buoyant force?
How could there be a buoyant force if there's no water below it pushing up?
So if the bottom of the pool were a scale, and the cube were all the way on the bottom (with no water between) doesn't that mean it would actually weigh more? (normal weight + weight from water pressure above)
And that when people ask that hypothetical question, "What would you weigh on a scale underwater?" and expect the answer to be your weight minus the buoyant force, wouldn't that answer only be approximately true? (Since some of the buoyant force from below your feet doesn't exist. It would still be approximate though because the majority of the buoyant force would likely come from the irregular shape of the human body.)
I have a feeling that I'm wrong in thinking this but I cannot seem to figure out how there would be a buoyant force (on a cube) without water being beneath it.
You aren't wrong provided that you make certain there is no fluid between the flat face of the object and the bottom surface.
Of course it's hard to keep the fluid from getting between the flat face and the bottom of the pool, as there's a fair amount of water pressure pushing it in there. But it can be done... Think about a suction cup stuck to the bottom of the pool.
Your apparent weight as measured by such a scale would be given by your true weight minus the weight of the fluid that you displace regardless of whether you are wearing golf shoes with sharpened spikes, shoes with flippers or shoes with suction cups.
If you don't want to equate the weight of the fluid that is displaced with the "buoyant force", that's fine. But that leaves you with no easy way to compute the "buoyant force" and no obvious reason to need to do so. So I see no good reason to adopt such terminology.
The problem is that this works well for a completely immersed body, not so well if the a portion of the body is "dry" due to being up against the bottom. Sure in that situation it is still displacing water, but for an upward force to occur, to which surface does that upward force apply? The buoyant force is ultimately a fluid force and as such can only occur on faces that are exposed to the fluid. Buoyancy ultimately arises from the hydrostatic pressure, so the only way to get an upward buoyant force is for there to be some surface with a nonzero normal component in the downward direction that is exposed to the fluid. A cube with a perfectly dry bottom face does not have such a surface.
Makes sense, thanks. Nugatory's suction cup would be an example where computing the force required to lift an object by naively taking gross weight minus buoyancy would be woefully inadequate.
Related to Buoyant Force at the bottom of a pool?
1. What is buoyant force at the bottom of a pool?
The buoyant force at the bottom of a pool is the upward force exerted by a liquid on an object submerged in it. It is a result of the pressure difference between the top and bottom of the submerged object.
2. How is the buoyant force at the bottom of a pool calculated?
The buoyant force at the bottom of a pool is calculated using Archimedes' principle, which states that the buoyant force is equal to the weight of the fluid displaced by the object. This can be calculated by multiplying the density of the fluid by the volume of the displaced fluid.
3. Does the buoyant force at the bottom of a pool change with depth?
Yes, the buoyant force at the bottom of a pool changes with depth due to the change in pressure. As depth increases, the pressure also increases, resulting in a greater buoyant force on the submerged object.
4. How does the buoyant force at the bottom of a pool affect the weight of an object?
The buoyant force at the bottom of a pool reduces the effective weight of an object, making it appear lighter. This is because the buoyant force counteracts the force of gravity, resulting in a net force that is less than the object's actual weight.
5. Can the buoyant force at the bottom of a pool be greater than the weight of an object?
Yes, the buoyant force at the bottom of a pool can be greater than the weight of an object, especially if the object is less dense than the fluid it is submerged in. This results in the object floating to the surface of the pool.
