C*-algebra with certain involution and multiplication is an *-algebra
HeinzBor
39
C*-algebra which may or may not be unital.
involution and multiplication given by:
Let $$\mathcal{A}$$ be a $C*$-algebra which may or may not have a unit with norm $$||.||$$, and put $$\mathcal{\overline{A}} = \mathcal{A} \oplus \mathbb{C}$$ as a vector space with mupltiplication:
$$(a, \lambda) (b, \mu) = (ab + \lambda b + \mu a , \lambda \mu)$$,
$$(a, \lambda)^{*} = (a^{*}, \overline{\lambda}).$$
Then I must show that $$\mathcal{\overline{A}}$$ is a $$*$$-algebra with unit 1 = (0,1).
1)
(0,1) is the unit since:
$$(a, \lambda)(0,1) = (a0 + \lambda 0 + 1a , \lambda 1) = (a, \lambda)$$
2)
$$(A^{*})^{*} = A \forall \mathcal{\overline{A}}$$ since:
$$((a, \lambda)^{*})^{*} = (a^{*}, \overline{\lambda})^{*} = (a^{**}, \overline{\overline{\lambda}}) = (a, \lambda)$$.
However I am struggling a bit with showing that
3) $$(aA + bB)^{*} = (\overline{a} A^{*} + \overline{b} B^{*}) \ \forall A,B \in \overline{\mathcal{A}}, a,b \in \mathbb{C}$$
and
4) $$(AB)^{*} = B^{*} A^{*}$$
\begin{align*}
(\mu A +\nu B)^*&=(\mu(a,\alpha )+\nu(b,\beta ))^*=((\mu a,\mu \alpha )+(\nu b,\nu \beta ))^*\\
&=(\mu a+ \nu b,\mu \alpha +\nu \beta )^*=((\mu a+\nu b)^*,\overline{\mu \alpha +\nu \beta})\\
&=(\overline{\mu}a^*+\overline{\nu}b^*,\overline{\mu} \cdot \overline{\alpha }+\overline{\nu}\cdot \overline{\beta })\\
&= \ldots
\end{align*}
Where exactly are your difficulties?
fresh_42 said:
\begin{align*}
&= \ldots
\end{align*}
Alright now it is clear! I was stuck because I didn't know that I was allowed to set $$(\mu a + vb)^{*}) = (\overline{\mu} a^{*} + \overline{v} b^{*})$$. (which should just be applying the involution) But from your last step it is just one time applications of vector space structure, pull out the scalars and then one substitution thanks a lot!
HeinzBor said:
Alright now it is clear! I was stuck because I didn't know that I was allowed to set $$(\overline{\mu} a^{*} + \overline{v} b^{*}) = ((\overline{\mu} a^{*}, \overline{\mu} \ \overline{\alpha} ))$$. But from your last step it is just one time applications of vector space structure, pull out the scalars and then one substitution thanks a lot!
Typo?
fresh_42 said:
Typo?
big time , fixed now
For the last one I end up here.
$$(b, \beta)^{*} (a, \alpha)^{*} = (b^{*}, \overline{\beta})(a^{*}, \overline{\alpha})
= (b^{*} a^{*} + \overline{\beta}a^{*} + \overline{\alpha}b^{*}, \overline{\beta} \overline{\alpha}) = (a^{*} B^{*} + \overline{\alpha} b^{*}, \overline{\beta} \overline{\alpha})$$
\begin{align*}
(b^*a^*+\overline{\beta }a^*+\overline{\alpha }b^*,\overline{\beta }\cdot \overline{\alpha })&=
(b^*a^*,\overline{\beta }\cdot \overline{\alpha })+(\overline{\beta }a^*,\overline{\beta }\cdot \overline{\alpha })+(\overline{\alpha }b^*,\overline{\beta }\cdot \overline{\alpha })\\
&=(ab,\alpha \beta )^* + \left(\beta (a,\alpha )\right)^*+\left(\alpha (b,\beta )\right)^*\\
&=\left((ab,\alpha \beta ) +\beta (a,\alpha )+\alpha (b,\beta )\right)^*\\
&=\left((a,\alpha )\cdot (b,\beta )\right)^*
\end{align*}
It is all about the definitions you gave in post #1 and the previous linearity.
If you want to practice such things then a good exercise would be the following:
Prove that ##(G,\cdot)## is a group if and only if ##xa=b## and ##ax=b## have unique solutions for all ##a,b\in G.##
What's also helpful: enumerate all properties a ##C^*##-algebra has, extended by those you have already proven for its unital extension, and write the numbers at each step of your calculations. This way you see what you used where.
fresh_42 said:
\begin{align*}
\end{align*}
Yes starting with the vector space structure axiom, I wasn't sure I could use it in that way in this setting.. Thanks again! I will try to go through that it has been too long ago since I took an algebra course!
