C/C++ C++ Coding question (How do I do it?)
  • Thread starter Thread starter carl123
    C++ Coding
The discussion focuses on completing a C++ program that calculates a student's total course percentage based on weighted scores from homework, midterm, and final exams. Participants suggest incremental steps, starting with running the program and progressively adding calculations for the midterm and final exams. They recommend using constant variables for maximum scores and weights, and introducing a function to streamline the calculation process for each assessment. Additionally, the program can be modified to include quiz scores, adjusting the weights accordingly. Overall, the emphasis is on structuring the code for clarity and ease of modification.
carl123
The following incomplete program should compute a student's total course percentage based on scores on three items of different weights (%s):
20% Homeworks (out of 80 points)
30% Midterm exam (out of 40 points)
50% Final exam (out of 70 points)
Suggested (incremental) steps to finish the program:
First run it.
Next, complete the midterm exam calculation and run the program again. Use the constant variables where appropriate.
Then, complete the final exam calculation and run the program. Use the constant variables where appropriate.
Modify the program to include a quiz score out of 20 points. New weights: 10% homework, 15% quizzes, 30% midterm, 45% final. Run the program again.
To avoid having one large expression, introduce variables homeworkPart, quizPart, midtermPart, and finalPart. Compute each part first; each will be a number between 0 and 1. Then combine the parts using the weights into the course value.
#include <iostream>
using namespace std;
int main() {
const double HOMEWORK_MAX = 80.0;
const double MIDTERM_MAX = 40.0;
const double FINAL_MAX = 70.0;
const double HOMEWORK_WEIGHT = 0.20; // 20%
const double MIDTERM_WEIGHT = 0.30;
const double FINAL_WEIGHT = 0.50;
double homeworkScore = 0.0;
double midtermScore = 0.0;
double finalScore = 0.0;
double coursePercentage = 0.0;
cout << "Enter homework score:" << endl;
cin >> homeworkScore;
cout << "Enter midterm exam score:" << endl;
cin >> midtermScore;
cout << "Enter final exam score: " << endl;
cin >> finalScore;
coursePercentage = ((homeworkScore / HOMEWORK_MAX) * HOMEWORK_WEIGHT)
+ 0.0 // FIXME for midterm
+ 0.0; // FIXME for final
coursePercentage = coursePercentage * 100; // Convert fraction to %
cout << endl << "Your course percentage (FIXME): ";
cout << coursePercentage << endl;
return 0;
Technology news on Phys.org
First of all I recommend having preprocessor symbols for data provided
Code:
#define HOMEWORK_MAX  80
#define MIDTERM_MAX      40 ...
Since calculation for each test procedure (ie midterm, assignment etc.) is same we can create a separate function for that
Code:
double CalculateResults(double dReceivedMarks, double dMaxMarks, double dPercentage)
         double dMarks = (dReceivedMarks/dMaxMarks)*dPercentage*100;
         return dMarks;
For main() method you can get the result for each test procedure as,
Code:
int main()
    dMidTermResults = CalculateResult(dMidTermScore, MIDTERM_MAX, MIDTERM_WEIGHT);
Similarly use the function for finding HomeWorkResults and FinalResults
And for final results sum up all three variables
Code:
int main()
    dTotalScore = dMidTermResults + dHomeWorkResults + dFinalResults;
By using these method you can easily modify the program when the requirements change
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
