What does the space above 'E' represent in a C++ deque diagram?
  • C/C++
  • Thread starter GeorgeCostanz
  • Tags
    C++ Diagram
In summary, the conversation discusses a diagram and its inaccuracies regarding a deque container. The initial capacity of the deque is 4 and several operations are performed, including push_back and pop_front. However, there are issues with the diagram, such as incorrect terminology and missing elements. The final answer should have an initial order of 7, 6, 5, followed by 42, 42, 1, 2, 3, 4.
GeorgeCostanz
31
I have a minor question about this diagram I'm hoping someone can clear up for me.
The deque has initial capacity 4. The following operations are performed.
push_back(1)
push_back(2)
push_back(3)
pop_front()
pop_front()
push_back(4)
push_front(5)
push_front(6)
push_front(7)
final answer:
I'm just wondering what the space above the letter 'E' is supposed to signify. I thought there were only 2 empty slots in the deque for the 2 pop_front operations at initial capacity 4.
Technology news on Phys.org
There are a number of things wrong with this question and the diagram. One is the word "capacity". Vectors have a capacity. Deques don't. Vectors and deques have a size, the number of elements currently in the container. Capacity is something different. I'm assuming that size was meant here: There are four items in the deque prior to those operations.
The second thing wrong is those three holes in the middle of the diagram. As you noted, that should be two holes. Those two pop_front() calls will remove the first two items from the deque, and since all operations up until then were on the back, the removed items are from that initial content of four items.
The third thing that's wrong: What happened to the 1 and the 2?
Finally, the order of the first three items is incorrect. It should be 7,6,5 rather than 5,6,7.
Code:
#include <deque>
#include <iostream>
int main () {
   std::deque<int> d(4,42);
   d.push_back(1);
   d.push_back(2);
   d.push_back(3);
   d.pop_front();
   d.pop_front();
   d.push_back(4);
   d.push_front(5);
   d.push_front(6);
   d.push_front(7);
   for (std::deque<int>::iterator iter = d.begin(); iter < d.end(); ++iter) {
      std::cout << *iter << " ";
   std::cout << "\n";
The above prints 7 6 5 42 42 1 2 3 4.
Likes 1 person
okay thanks. i found it on a random HW solution set on the internet.
FAQ: What does the space above 'E' represent in a C++ deque diagram?
What is a C++ deque diagram?
A C++ deque diagram is a visual representation of a deque data structure in the C++ programming language. It shows the organization of data in a deque, including the front and back ends and the elements stored in between.
2. How is a C++ deque diagram different from other data structure diagrams?
A C++ deque diagram is unique in that it represents a double-ended queue, which allows elements to be inserted and removed from both ends. Other data structure diagrams may only show one direction of insertion or removal, such as a stack or queue.
3. What are the benefits of using a C++ deque diagram?
A C++ deque diagram helps to visualize the structure of a deque, making it easier to understand and implement in code. It also allows for efficient manipulation of elements at both ends of the deque, making it a versatile data structure for certain applications.
4. How do you draw a C++ deque diagram?
To draw a C++ deque diagram, start by drawing a rectangular box with two arrows pointing to it on either side. This represents the two ends of the deque. Then, draw boxes in between the arrows to represent the elements stored in the deque. Finally, label the arrows as "front" and "back" to indicate the direction of insertion and removal.
5. What are some common operations performed on a C++ deque?
Some common operations performed on a C++ deque include inserting and removing elements from the front and back ends, checking the size of the deque, and accessing specific elements. Other operations may include sorting, searching, and merging deques.
