C/C++ C++: Determining If a String Contains A Numeric Digit
  • Thread starter Thread starter ineedhelpnow
    Numeric String
To determine if a 3-character passCode contains a digit, set the boolean variable hasDigit to true if a digit is found. A suggested approach involves using a "for" loop to iterate through each character of the passCode string. The loop should check if each character is a digit, and if a digit is detected, hasDigit should be set to true, and the loop should exit early. The loop's index should be less than the size of the passCode string. Additionally, while some users prefer traditional character arrays or other string types, utilizing std::string is recommended for its built-in functions like substr(), replace(), and find_first_of(), which can simplify the implementation.
ineedhelpnow
Set hadDigit to true if the 3-character passCode contains a digit.
Sample program:
Code:
#include
#include
#include
using namespace std;
int main() {
   bool hasDigit = false;
   string passCode;
   int valid = 0;
   passCode = "abc";
   <student code>
   if (hasDigit) {
      cout << "Has a digit." << endl;
   else {
      cout << "Has no digit." << endl;
   return 0;
I'm super lost on this. I could definitely use some help/hints. Thanks
Technology news on Phys.org
One way to do this would be to use a "for" loop and check each character in the string sequentially to see if it is a digit or not. Once the first digit is detected, then hasDigit should be set to true and the loop should be broken, otherwise the loop will have checked all characters in the string and hasDigit will remain false.
For the "for" loop you will need the size of "passCode" as the value that the loop's index should be less than.
Also, it appears you need to include some libraries...
I can't say I am a fan of std::string in C++ as there are people who still insist on using char* or CString if you are using Microsoft stuff (and all the compatibility issues of these "string" classes).
However, if you are already using std:string, I would suggest you look at the reference of that library:
string - C++ Reference
It already provided handy functions like substr(), replace() and find_first_of() that answer a number of questions you posted fairly simply.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
