C F Gauss, on how to add all numbers of 1 to 100?
In summary, Mark on Yahoo answers asks how to add all numbers from 1 to 100, and other users provide different methods to solve this problem. One method involves arranging the numbers in pairs and using a formula, while another method uses symbolic differencing and a recursion approach. Both methods result in the same formula, which is $\frac{n(n+1)}{2}$, where n is the highest number in the sequence. Other users also share methods to find the sum of sequences of natural number powers of integers.
CaptainBlack
807
Mark on Yahoo answers asks:
Carl gauss 1777 1855 , on how to add all numbers of 1 to 100?
I can only add from 1 to 100 in order, apparently he could add lighteningly fast, and backwards, can anyone explain how in the confines of one message on here please
Allegedly his method was something like:
$(1+100)+(2+99)+ ... +(99+2)+(100+1)=2(1+2+...+100)$
But the left hand side is $101\times 100$, so $1+2+..100=101\times 100/2$
(Like Marlow's Dr Faustus he could sum them forwards and backwards - but had no need of anagramatisation)
CB
Mathematics news on Phys.org
This also works for any sum:
$\displaystyle \sum_{k = 1}^{n} k = 1 + 2 + \cdots + n $
This sum can be reorganized in this fashion:
$\displaystyle \left ( 1 + \left ( n \right ) \right ) + \left ( 2 + \left ( n - 1 \right ) \right ) + \cdots + \left (n + \left (1 \right ) \right )$
This produces $n$ sums of $n + 1$, so the total sum is $n(n + 1)$. But note that this goes through the list twice, from the left and from the right (for instance, $1$ is added to $n$ at the beginning and at the end). So this is actually twice the sum we need, we conclude:
$\displaystyle \sum_{k = 1}^{n} k = \frac{n(n + 1)}{2}$
$n = 100$ can then be easily calculated from the formula, just as can $n = 4885$ or $n = 6$ ;)
I would like to share two more ways of doing this.
Proof #0 (Notice that what Gauss did is basically this):
$\begin{aligned} \displaystyle & \sum_{0 \le k \le n}k = \sum_{0 \le k \le n}(n-k) = n\sum_{0 \le k \le n}-\sum_{0 \le k \le n}k \\& \implies 2\sum_{0 \le k \le n}k = n(n+1) \implies \sum_{0 \le k \le n}k = \frac{1}{2}n(n+1).\end{aligned}$
Proof #1 (Now try that with $\sum_{0 \le k \le n}k^2$ and you will be pleasantly surprised):
$\begin{aligned} \displaystyle & \sum_{0 \le k \le n}k^2 = \sum_{0 \le k \le n}(n-k)^2 = n^2\sum_{0 \le k \le n}-2n\sum_{0 \le k \le n}k+\sum_{0 \le k \le n}k^2 \\& \implies 2n\sum_{0 \le k \le n}k = n^2(n+1) \implies \sum_{0 \le k \le n}k = \frac{1}{2}n(n+1).\end{aligned}$
Proof #2 (Writing it as a double sum and switching the order of summation):
$\begin{aligned}\displaystyle & \begin{aligned}\sum_{1 \le k \le n}k & = \sum_{1 \le k \le n}~\sum_{1 \le r \le k} = \sum_{1 \le r \le n} ~\sum_{r \le k \le n} = \sum_{1 \le r \le n}\bigg(\sum_{1 \le k \le n}-\sum_{1 \le k \le r-1}\bigg) \\& =\sum_{1 \le r \le n}\bigg(n-r+1\bigg) = n\sum_{1 \le k \le n}-\sum_{1 \le k \le n}k+\sum_{1 \le k \le n}\end{aligned} \\& \implies 2\sum_{1 \le k \le n}k = n^2+n \implies \sum_{1 \le k \le n}k = \frac{1}{2}n(n+1), ~ \mathbb{Q. E. D.}\end{aligned}$
Warning: extremely long-winded post ahead! (Malthe)
Here are two closely related methods to derive the formulas for summations of sequences of natural number powers of integers from 0 - n.
Method 1: A "bottom-up" approach...
We may state:
$\displaystyle\sum_{k=0}^n(k)=\sum_{k=0}^n(k+1)-(n+1)$
$\displaystyle\sum_{k=0}^n(k)=\sum_{k=0}^n(k)+\sum_{k=0}^n(1)-(n+1)$
$\displaystyle0=\sum_{k=0}^n(1)-(n+1)$
$\displaystyle\sum_{k=0}^n(1)=n+1$
Now we may compute:
$\displaystyle\sum_{k=0}^n(k)$
We may state:
$\displaystyle\sum_{k=0}^n\left(k^2 \right)=\sum_{k=0}^n\left((k+1)^2 \right)-(n+1)^2$
$\displaystyle\sum_{k=0}^n\left(k^2 \right)=\sum_{k=0}^n\left(k^2+2k+1 \right)-(n+1)^2$
$\displaystyle\sum_{k=0}^n\left(k^2 \right)=\sum_{k=0}^n\left(k^2 \right)+2\sum_{k=0}^n(k)+\sum_{k=0}^n(1)-(n+1)^2$
$\displaystyle2\sum_{k=0}^n(k)=-\sum_{k=0}^n(1)+(n+1)^2$
Now, using our previous result, we have:
$\displaystyle2\sum_{k=0}^n(k)=-(n+1)+(n+1)^2$
$\displaystyle2\sum_{k=0}^n(k)=(n+1)\left(-1+(n+1) \right)$
$\displaystyle2\sum_{k=0}^n(k)=(n+1)(n)$
$\displaystyle\sum_{k=0}^n(k)=\frac{n(n+1)}{2}$
Now we may continue and find:
$\displaystyle\sum_{k=0}^n\left(k^2 \right)$
$\displaystyle\sum_{k=0}^n\left(k^3 \right)=\sum_{k=0}^n\left((k+1)^3 \right)-(n+1)^3$
$\displaystyle\sum_{k=0}^n\left(k^3 \right)=\sum_{k=0}^n\left(k^3+3k^2+3k+1 \right)-(n+1)^3$
$\displaystyle\sum_{k=0}^n\left(k^3 \right)=\sum_{k=0}^n\left(k^3 \right)+3\sum_{k=0}^n\left(k^2 \right)+3\sum_{k=0}^n(k)+\sum_{k=0}^n(1)-(n+1)^3$
$\displaystyle3\sum_{k=0}^n\left(k^2 \right)=-3\sum_{k=0}^n(k)-\sum_{k=0}^n(1)+(n+1)^3$
Using our previous results, we have:
$\displaystyle3\sum_{k=0}^n\left(k^2 \right)=-3\left(\frac{n(n+1)}{2} \right)-(n+1)+(n+1)^3$
$\displaystyle3\sum_{k=0}^n\left(k^2 \right)=(n+1)\left(-\frac{3n}{2}-1+(n+1)^2 \right)$
$\displaystyle3\sum_{k=0}^n\left(k^2 \right)=(n+1)\left(-\frac{3n}{2}-1+n^2+2n+1 \right)$
$\displaystyle3\sum_{k=0}^n\left(k^2 \right)=(n+1)\left(n^2+\frac{n}{2} \right)$
$\displaystyle3\sum_{k=0}^n\left(k^2 \right)=\frac{n(n+1)(2n+1)}{2}$
$\displaystyle\sum_{k=0}^n\left(k^2 \right)=\frac{n(n+1)(2n+1)}{6}$
We may continue this process, to find further power summations.
Method 2: A recursion approach...
Suppose we want to find:
$\displaystyle S_n=\sum_{k=0}^n\left(k^3 \right)$
We may use the inhomogeneous recursion to state:
$\displaystyle S_n=S_{n-1}+n^3$
Now, we may use symbolic differencing to ultimately derive a homogeneous recursion.
We begin by replacing n with n + 1:
$\displaystyle S_{n+1}=S_{n}+(n+1)^3$
Subtracting the former from the latter, there results:
$\displaystyle S_{n+1}=2S_{n}-S_{n-1}+3n^2+3n+1$
$\displaystyle S_{n+2}=2S_{n+1}-S_{n}+3(n+1)^2+3(n+1)+1$
Subtracting again:
$\displaystyle S_{n+2}=3S_{n+1}-3S_{n}+S_{n-1}+6n+6$
$\displaystyle S_{n+3}=3S_{n+2}-3S_{n+1}+S_{n}+6(n+1)+6$
Subtracting again:
$\displaystyle S_{n+3}=4S_{n+2}-6S_{n+1}+4S_{n}-S_{n-1}+6$
$\displaystyle S_{n+4}=4S_{n+3}-6S_{n+2}+4S_{n+1}-S_{n}+6$
Subtracting again:
$\displaystyle S_{n+4}=5S_{n+3}-10S_{n+2}+10S_{n+1}-5S_{n}+S_{n-1}$
Now we have a homogeneous recursion whose associated characteristic equation is:
$\displaystyle (r-1)^5=0$
Since we have the root $\displaystyle r=1$ of multiplicity 5, we know the closed form for the sum will take the form:
$\displaystyle S_n=k_0+k_1n+k_2n^2+k_3n^3+k_4n^4$
We may use known initial values to determine the constants $\displaystyle k_i$.
$\displaystyle S_0=k_0=0$
This means, we are left with the 4X4 system:
$\displaystyle k_1+k_2+k_3+k_4=1$
$\displaystyle 2k_1+4k_2+8k_3+16k_4=9$
$\displaystyle 3k_1+9k_2+27k_3+81k_4=36$
$\displaystyle 4k_1+16k_2+64k_3+256k_4=100$
Did you notice we get the squares of successive triangular numbers? Anyway, solving this system, we find:
$\displaystyle k_1=0,k_2=\frac{1}{4},k_3=\frac{1}{2},k_4=\frac{1}{4}$
And so, we have:
$\displaystyle S_n=\frac{1}{4}n^2+\frac{1}{2}n^3+\frac{1}{4}n^4= \frac{n^4+2n^3+n^2}{4}=$
$\displaystyle\frac{n^2(n+1)^2}{4}=\left( \frac{n(n+1)}{2} \right)^2$
a nice combinatorial proof
View attachment 348To each yellow circle we can associate a pair of green circles in the way suggested by the drawing. This shows a bijection between (and hence the same number of) all the yellow circles and all the pairs of green circles.
Here, there are $1+2+3+4+5+6+7+8$ yellow circles, and the number of green-circle pairs is $\binom{9}{2}$; so $1+2+3+4+5+6+7+8=\binom{9}{2}$.
(I saw this 'proof without words' in a lecture by Gil Kalai)
CB
The way I heard it was that he noted, as you have, that 1+ 100= 101, 2+ 99= 101, etc. until 50+ 51= 101 so there were 50 sums, each totalling 101: 50(101)= 5050.
FAQ: C F Gauss, on how to add all numbers of 1 to 100?
What is the formula for adding all numbers from 1 to 100?
The formula for adding all numbers from 1 to 100 is n(n+1)/2, where n is the highest number in the range (in this case, 100).
Who was C F Gauss and what is his connection to adding all numbers from 1 to 100?
C F Gauss, also known as Carl Friedrich Gauss, was a German mathematician who developed the formula for adding all numbers from 1 to 100. He is considered one of the greatest mathematicians of all time and made significant contributions to various fields of mathematics.
Can the formula for adding all numbers from 1 to 100 be applied to other number ranges?
Yes, the formula can be applied to any range of consecutive numbers. As long as the highest number in the range is known, the formula will give the correct sum.
Why is the formula for adding all numbers from 1 to 100 important?
The formula for adding all numbers from 1 to 100 is important because it provides a quick and efficient way to find the sum of a large number of consecutive numbers. It is also a commonly used example in mathematics and is often used to introduce the concept of mathematical induction.
What is the significance of the number 100 in the formula for adding all numbers from 1 to 100?
The number 100 is significant because it represents the highest number in the range. The formula is based on the pattern that emerges when adding consecutive numbers, and 100 is the highest number in this particular range. The formula can be modified for other ranges by changing the highest number.
