C++ fmod() Function Returning Wrong Value. Why?
In summary, the conversation discusses a problem with using the fmod() function in a program to obtain values for a first order differential equation. The issue arises when x=0.6 and the function suddenly returns a remainder of 0.2 instead of 0. The experts suggest that this could be due to floating point representations and recommend using the remainder() function instead to check for a remainder that is close to zero.
phyzmatix
313
Good day!
I'm busy with a simple little program to obtain values for a first order differential equation using the second-order Runge-Kutta method. I want the program to only print values for x = 0, x = 0.2, x = 0.4...x = 1.2 and am using the fmod(double, double) function in the cmath header to determine when x is a multiple of 0.2 (i.e. the remainder of x/0.2 = 0).
The problem I have is that this function works perfectly well up until x=0.6 when suddenly it returns a remainder of 0.2 and it's driving me freaking nuts as I can't figure out why!
You can see from the console output where it starts going wrong (bold)
FracPart 0.0000000000
x 0.1000000000
FracPart 0.1000000000
x 0.2000000000
x 0.3000000000
x 0.4000000000
x 0.5000000000
x 0.6000000000
FracPart 0.2000000000
x 0.7000000000
x 0.8000000000
x 0.9000000000
x 1.0000000000
x 1.1000000000
x 1.2000000000
x 1.3000000000
My code:
Code:
#include <iostream>
#include <cstdlib>
#include <cmath>
using namespace std;
const double h = 0.1;
int main()
    double x, y, kOne, kTwo, exact, error;
    double a, b, alpha, beta;
    double fracPart, param, intPart;
    //initialises parameters
    a = 0.6666666667;
    b = 0.3333333333;
    alpha = 1.5;
    beta = 1.5;
    x = 0;
    y = 3;
    //writes table heading to console
    //cout << "x\t\t" << "y\t\t" << "Exact\t\t" << "Error\t\t" << endl;
    cout.setf(ios::fixed);
    cout.precision(10);
    //writes new rows to table
    do
        exact = 2 + exp(x)*pow(cos(pow(x,2)),3);
        error = exact - y;
        fracPart = fmod(x, 0.2);
        cout << "FracPart " << fracPart << endl;
        /*if(fracPart == 0)
           cout << x << "\t" << y << "\t" << exact << "\t" << error << endl;
        kOne = h * ((1-(6*x*tan(pow(x,2))))*(y - 2));
        kTwo = h * ((1-6*(x+alpha*h)*tan(pow((x+alpha*h),2)))*((y + beta*kOne) - 2));
        y += (a*kOne + b*kTwo);
        x += h;
        cout << "x " << x << endl;
    }while(x < 1.2);
    system("PAUSE");
    return 0;
I'm using DevC++ v 4.9.9.2 and minGW.
Any help will be greatly appreciated!
phyz
My bet would be - without even trying to analyse your code - that you are a victim of floating point representations and numerical accuracy. That is what is displayed as 0.2 is in fact 0.199999999999 or something like that.
Print (unconditionally) error values to see what is happening.
Hi Borek!
I've thought of this, but I don't think that will be the case here as x is incremented each time with 0.1 exactly and isn't relying on a calculation...
Having said that though, if I understand you correctly (removing the lines cout.setf(ios::fixed);
and cout.precision(10);) I get:
FracPart 0
x 0.1
FracPart 0.1
x 0.2
FracPart 0
x 0.3
FracPart 0.1
x 0.4
FracPart 0
x 0.5
FracPart 0.1
x 0.6
FracPart 0.2
x 0.7
FracPart 0.1
x 0.8
FracPart 0.2
x 0.9
FracPart 0.1
x 1
FracPart 0.2
x 1.1
FracPart 0.1
x 1.2
Which is exactly the same thing minus a load of zero's...or did you mean something else?
You have just discovered two features (mis-features) about numerical computing:
  1. In general it is not a good idea to test for an exact match with doubles.
  2. fmod() returns counterintuitive results.
Suppose your computer used base 10 arithmetic (which it doesn't). In base 10, there is no way to represent 1/3=0.333... exactly in a finite number of digits. A base 10 computer would have to approximate 1/3. The same thing happens with 0.2. Your computer cannot represent 0.2 exactly. This leads to some apparently odd results such as those you obtained.
One solution is to use remainder() rather than fmod() and check for a remainder that is close to zero rather than exactly equal to zero.
Edit
Borek beat me to it.
Thanks for your help guys! I got it.
Edit
Thanks for this, I never thought of it this way.
It turns out that remainder() is not a part of the math library. It is a part of C99. I use gcc/g++, which doesn't complain a bit about using C99 functionality in C++. So beware, <rant>and dang, sometimes I wonder why we ever switched to C and then C++ from Fortran decades ago. C's math library is pathetic; its beyond pathetic with C++.</rant>
I guess this:
is in answer to this:
phyzmatix said:
Hi DH
Thanks for the help earlier on. I just have to ask, I can't find a single reference to the remainder() function and yet it obviously exists as (1) you know about it and (2) it works.
You wouldn't happen to have a link to a good C++ reference library? (I'm not sure if that's the correct phrase, hope you understand). The one I've been using mostly is http://www.cplusplus.com/reference/ but, as I said, no mention of remainder() that I can find so I'm wondering what else I'm missing.
Cheers and have a good day!
phyz
:smile:
(sorry I was a bit slow on the draw there)
\sum_{0}^{\infty}{\displaystyle cx}\frac{6\sqrt[3x]{g}}{9n+1}
Related to C++ fmod() Function Returning Wrong Value. Why?
1. Why is my C++ fmod() function returning the wrong value?
The most common reason for this is that the input arguments are not being passed correctly. Make sure that the arguments are of the correct data type and are in the correct order. Another possibility is that there is a logical error in your code causing the incorrect value to be returned.
2. What data types can fmod() function handle?
The fmod() function is designed to work with floating-point numbers, so it can handle data types such as float and double. It cannot work with integers or other non-floating point data types.
3. How does the fmod() function handle division by zero?
If the second argument of the fmod() function is zero, the function will return a NaN (not a number) value. It is important to handle this possibility in your code to avoid any unexpected results.
4. Can the fmod() function be used to calculate the remainder of two negative numbers?
Yes, the fmod() function can handle negative numbers as input arguments and will return the correct remainder. However, it is important to note that the remainder of two negative numbers may not be intuitive and may require additional logic in your code to handle it correctly.
5. What is the difference between fmod() and remainder() functions in C++?
While both functions can be used to calculate the remainder of two numbers, they differ in their behavior when dealing with negative numbers. The fmod() function follows the C99 standard and returns a result with the same sign as the dividend (first argument), while the remainder() function follows the IEEE 754 standard and returns a result with the same sign as the divisor (second argument).
