MHB C Function Help - Solve Issues with Void Function
  • Thread starter Thread starter Colton0117
    Function
The discussion revolves around issues with implementing a void function in C that inserts zeros between elements of an input array. The user has provided code but is struggling to make the function work correctly, particularly due to not calling the function in the main section. There is also a syntax error identified in the function header, which has been corrected, but the user still faces challenges with the overall functionality. The expected output format is specified, and the user seeks assistance to ensure the program operates as intended. Overall, the main concern is effectively integrating the void function to achieve the desired output array.
Colton0117
I am having issues making my function work. If there is not a void function included, my program works as intended but sadly I need to have a function. I am at a loss as how to implement this type of function. The requirements are below and any help asap would be GREATlY appreciated!
Write a program that include the following function:
void insert0(int n, int a1[], int a2[]);
In the main function, ask the user to enter the length of the input array, declare the input and output arrays, read in the values for the input array, and call the insert0 function to compute the output array. The main function should display the result of the output array.
Enter the length of the array: 5
Enter the elements of the array: 3 4 9 1 4
Output: The output array is: 3 0 4 0 9 0 1 0 4 0
My code:
Code:
#include <stdio.h>
int main() {
int i = 0;
int n = 0;
int a1[n];
int a2[n * 2];
printf("Enter the length of the array: ");
scanf("%d",&n);
printf("Enter the elements of the array: ");
for(i = 0; i < n; i++){ //adds values to first array
        scanf("%d",&a1[i]);
//call function here
for( i = 0; i < n*2; i++){ //prints array 2
        printf("%d", a2[i]);
void insert0 (int n, int a1[], int a2[]){//inserts 0's between each number
        a2[i+i] = a1[i];
        a2[i+i+1] = 0;
        return 0;
Technology news on Phys.org
My code:
Code:
#include <stdio.h>
int main() {
int i = 0;
int n = 0;
int a1[n];
int a2[n * 2];
scanf("%d",&n);
        scanf("%d",&a1[i]);
void insert0 (int n, int a1[], int a2[]); //inserts 0's between each number   <------ This line is the problem
        a2[i+i] = a1[i];
        a2[i+i+1] = 0;
        return 0;
Look carefully at the function header, the marked line, for your insert0 function you have syntax error on the line.
I have fixed that issue, although that was just a typo and not my actual problem.
OK, then what's wrong with your solution, other than you haven't called the function in main?
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
