C/C++ C++ Homework Help: Calculate Product of Numbers
  • Thread starter Thread starter dnc1786
    C++ Homework
The discussion revolves around a programming assignment that requires calculating the product of numbers from 2 up to a user-defined integer between 3 and 10. The initial code provided works correctly for inputs 3 to 5 but fails for higher values due to an error in how the product is calculated within the loop. The user is guided to adjust their logic to ensure that the product accumulates correctly as the loop iterates through the numbers. The revised code suggests using a different approach to manage the product calculation and ensure the output format matches the expected result. Key points include the importance of correctly initializing and updating the product variable, as well as ensuring the loop iterates through the correct range of numbers. The discussion emphasizes debugging and refining code to achieve the desired functionality.
dnc1786
I am not looking for an answer, just guidance...
My assignment is to ask the user for a number between 3 and 10 (inclusive). Using a loop, calculate the product of the numbers between 2 and that number. For example, if the user chooses 5, the result would be 2 x 3 x 4 x 5 = 120.
Sample run: When input is:
The output exactly matches
Please enter a number from 3 to 10: 5
2 x 3 x 4 x 5 = 120
So far I have come up with this, which works perfectly for input 3 through 5. However, the product is wrong when the input is anything above five and I am completely lost as to what is wrong with the code:
Code:
#include <iostream>
using namespace std;
int main (){
   int userInt = 0;
   int multiple = 2;
   int product = 1;
cout << "Please enter a number from 3 to 10: ";
cin >> userInt;
cout << userInt << endl;
if ((userInt < 3) || (userInt >= 11)){
   cout << "Please follow the directions!" << endl;
else {
   cout << "2";
   ++multiple;
   while (multiple <= userInt){
      cout << " x " << multiple;
      ++multiple;
      product = product * multiple;
cout << "  = " << product << endl;
return 0;
Technology news on Phys.org
I take it you finished your homework... In any case:
C++:
#include <iostream>
int main (){
    int userInt = 0;
    cin >> userInt;
    cout << userInt<< endl;
    if (!(userInt >= 3 && userInt <= 10)) {
    } else {
    cout << "2";
    uint multiplier = 2;
    uint result = userInt;
    while (userInt > 2) {
        cout << " x " << ++multiplier;
        result *= (userInt - 1);
        userInt--;
    cout << " = " << result << endl;
    return 0;
Compile, debug and run here.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
