C/C++ C++ How to invoke an object's method in a different file
  • Thread starter Thread starter Bob Walance
    C++ programming
The discussion revolves around the challenge of accessing a method from a class object defined in one source file (timer_functions.cpp) within another file (interrupts.cpp). The user created an instance of the Timers class but encountered build errors when trying to call its method from interrupts.cpp. The main issue identified is the improper declaration and linking of the object across files. Suggestions include using a static instance of the Timers class to avoid the need for creating and destroying the object with each interrupt, which simplifies the process. The solution of using a single global instance was confirmed as effective for the user's application, resolving the initial problem.
Bob Walance
Insights Author
TL;DR Summary
In C++, how to run a method from an object that was created in a separate file.
I have created an object for the class Timers in timer_functions.cpp, and I need to run a method associated with that object ( test_method() ) from interrupts.cpp.
I've tried many things but have been unsuccessful. Any ideas would be appreciated. Here is some sample code:
classes.hpp
C++:
   #pragma once
   class Timers {
   public:
     void test_method(void);
   private:
     int testVariable;
classes.cpp
C++:
#include classes.hpp
   void Timers::test_method(void) {
     testVariable++;
timer_functions.cpp
C++:
   Timers myTimerObject; // create the object
interrupts.cpp
C++:
   extern Timers myTimerObject; // this doesn't eliminate the build error
   void timer_interrupt(void) {
     myTimerObject.test_method(); // trying to run the objects method, but BUILD ERROR
Technology news on Phys.org
I'm not clear on what you are trying to do, and how things are split up. Normally, if you have a class foo, there is a header foo.hh and the actual code in foo.cc. If I have code bar.cc, it includes foo.hh, and the linker links foo.o and bar.o.
I don't see how your snippets match to this, but you seem to be creating an instance of an object in one file and using it in another. That shouldn't work - it shouldn't even compile, because the object isn't even declared in the second file. (And if it is declared, how does the compiler know it is supposed to be the same as in the first?)
Normally code would create the object and pass it to other code through a pointer to that object. The same code that created it should destroy it when it is no longer needed,
I don't want to create and destroy the instance for each periodic timer interrupt. While this would probably work, it seems messy.
A pointer to the instance could be created in timer_functions.cpp, but how would it get passed to the timer interrupt?
If you intend to have only a single (global) instance of Timers, then you can use a "static" instance. In that case, read up on static class variables and static member fns.
Of course, if you do indeed intend that, then why call it "Timers" (plural) instead of "Timer" singular?
Likes Vanadium 50 and Bob Walance
Wow. That works!
Yes, a single instance of the class (really it's no instance) is just fine for my application.
Thank you for the simple solution.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
