C/C++ [C++] How to return and call vectors from functions?
  • Thread starter Thread starter Yohanna99
    Functions Vectors
The discussion focuses on a beginner coder's challenges with using vectors as parameters and return values in C++. The coder seeks clarification on how to properly call functions that return vectors and how to handle vector parameters. Specific code examples are provided, including functions for gathering string inputs and calculating the average of a vector of floats. Key points include the need to output the return values from these functions and the suggestion to initialize variables properly. The response emphasizes that vectors can be returned like any other object, and provides direct code snippets to demonstrate how to output the return values from the defined functions.
Yohanna99
Hi, beginner coder here. I have a somewhat solid understanding of both vectors and functions, and have used the two of them many times, but I'm have trouble coding functions that have vectors in their parameters and as their return values.
Another thing I'm having trouble with is calling the return value from a function when the parameter is a single vector. The c++ forum explains how to call the return when the parameters are variables and I get that but there's no example with vectors.
Technology news on Phys.org
Could you give some specific code that you've tried with exactly what you want it to do? There's really nothing special about a vector object that is returned from a function; the only thing possibly is whether it is a reference to the object, pointer to the object or an object itself.
This is very rough code just to give you an idea. Ignore things that may make no sense I'll edit it again soon.
Code:
#include <iostream>
#include <string>
#include <vector>
using namespace std;
string get_string_input(vector<string> strings);
float averageFunc(vector<float> floating);int main()
	cout << "enter a word. When you're done, enter done." << endl;
	vector<string> strings;
	string input;
	while (input != "done")
		cin >> input;
		if (input == "done")
			break;
		else
			strings.push_back(input);
	}	cout << "your sentence is: ";
	for (int i = 0; i < strings.size(); i++) {
	// how to output return val from get_string_input
	cout << "enter a num. When you're done, enter 10001." << endl;
	vector<float> floating;
	float num;	while (num != 10001)
		cin >> num;
		if (num == 10001)
			break;
		else
			floating.push_back(num);
	// how to output return val from averageFunc	system("pause");
	return 0;
The first function will be get_string_inputs, which will return a vector of strings.
This function should continually loop, taking input from cin, and putting that into
the vector that will be returned. It should take one parameter, which is the string
to take in that will denote that input should stop being received. When this input
is found, the function will return the vector.
string get_string_input(vector<string> strings) {	string s;
		s = strings[i];
		cout << s << " ";
	return s;
The second function will be an average function. This function should
take a vector of floats as input, and return a single float value that
is the average of the vector passed in.
float averageFunc(vector<float> floating) {
	float total = 0.0;
	for (int i = 0; i < floating.size(); i++)	{
		total += floating[i];
	float avrg = total / floating.size(); // average of vector
	return avrg;
Hi Yohanna99! Welcome to MHB! (Smile)
It appears you're looking for:
Code:
cout << get_string_input(strings) << endl;
cout << averageFunc(floating) << endl;
Oh, and [m]num[/m] should really be initialized:
Code:
float num = 0;
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
