C# noob with a little problem here
  • C#
  • Thread starter stonecoldgen
  • Tags
    Noob
In summary, the code is attempting to determine if a given number is less than 10, but is not converting the input into an integer before performing the comparison. This can be fixed by using Int32.Parse(Console.ReadLine()) instead of Console.Read().
stonecoldgen
109
Hi, so I have this code:
Code:
namespace Program1
    class Program
        static void Main(string[] args)
            Console.WriteLine("Is the numer less than 10?");
            int numero = Console.Read();
            if (numero < 10)
                Console.WriteLine("true");
            else
                Console.WriteLine("false");
The console is always writing the line "false" even if I input a number that should return "true."
any idea what am I doing wrong?
Technology news on Phys.org
maybe you have to cast the input into an integer as it comes in, else it converts to integer zero
Console.Read returns the ascii code for the key pressed, not the number itself.
Try this:
Code:
            int numero = Int32.Parse(Console.ReadLine());
Related to C# noob with a little problem here
1. What is C# and why is it important?
C# is a modern, object-oriented programming language that is widely used for developing a variety of applications. It is important because it is a versatile language that can be used for web development, game development, and other software development projects.
2. I am new to C# and I am having trouble understanding the syntax. What should I do?
If you are new to C# and struggling with the syntax, it is recommended to practice writing simple programs and refer to online resources, such as tutorials and documentation. Additionally, joining online communities or forums can provide valuable insights and support from experienced C# developers.
3. Why does my C# code keep showing errors?
There are various reasons why your C# code may have errors. Some common reasons include syntax errors, missing or incorrect library references, or logical errors in your code. It is important to carefully review your code and use debugging tools to identify and fix any errors.
4. How can I improve my C# coding skills?
To improve your C# coding skills, it is important to practice writing code regularly and to challenge yourself with new projects. Additionally, reading books and online resources, attending workshops or classes, and seeking feedback from experienced developers can also help in developing your skills.
5. Can I use C# to develop mobile applications?
Yes, C# can be used for mobile app development. There are frameworks such as Xamarin and Unity that allow developers to use C# to build cross-platform mobile applications for both Android and iOS devices.
