C or FORTRAN compiler for Vista?
In summary, the problem with trying to compile C code on Vista is that the compiler won't recognize the code and will give you a lot of errors. However, you can download a compiler that works fine and also download a development environment that includes Fortran.
kde2520
Can anyone help me find a compiler/IDE for FORTRAN or C that can work with Windows Vista? I am a physics student and would like to learn some programing, but my computer runs Vista and I have yet to find a compiler that works.
Otherwise, are there any recommendations for a language I could learn that might be useful to me and that I won't run into such problems with on Vista?
(Please, please resist the impulse to tell me to can Vista and get XP... really...)
Technology news on Phys.org
No problem... just can Vista and get Linux instead. :biggrin: Or Mac OS X. :biggrin: :biggrin:
You know the solution and you are still asking question? Geez...
That being said, look for Visual Studio and Visual C++. No idea about exact licences available at the moment, but there were free academic or entry level versions available few years ago and the current version (whichever it is) has a three month free trial.
Or download Cygwin, which runs fine on Vista, and use the freeware GNU compiler collection, which includes C/C++ and FORTRAN.
- Warren
No problem... just can Vista and get Linux instead. Or Mac OS X.
Yes yes yes, I know I know... if I could keep one of you guru's in my back pocket to help with such things (or maybe talk me out of buying a computer loaded with Vista in the first place), or maybe had more time and money to deal with it myself, I'd be in a different spot. In the meantime I have to use what I've got.
That being said, I have tried Visual Studio/Visual C++ with no luck (trying to compile in C, that is). I've also tried EclipseC and Bloodshed. I will try Cygwin next.
Thanks all.
Cygwin + JGrasp if you don't feel like learning command-line stuff.
You mean some specific C code, or just any C programs?
http://www.silverfrost.com/11/ftn95/overview.asp
From this link you can dowoload Fortran 95 compiler that works fine on Vista, in addition to plato 3 which is in integrated development environment.
As far as I know, the personal edition for free but it is not supposed to be used for research purposes.
No, just any C programs. Took a class in C last spring and this was a big problem. I had to run Eclipse and store my workspace on a flash drive instead of using my own computer.
Just downloaded the FTN95 compiler with Plato 3 that Useful Nucleus suggested. I'll let y'all know how it worked out once I get a chance to mess with it.
Strange, I am using an earlier Visual Studio and no problems with C compilation at all. What error messages did you get?
Are you sure, you know, that the code you're testing the compiler with is valid??
Related to C or FORTRAN compiler for Vista?
1. What is a C or FORTRAN compiler for Vista?
A C or FORTRAN compiler for Vista is a software program used to translate source code written in the C or FORTRAN programming languages into machine code that can be understood and executed by a computer running the Windows Vista operating system.
2. Why do I need a specific compiler for Vista?
Different operating systems require different compilers because they have different system architectures and code libraries. A C or FORTRAN compiler for Vista is specifically designed to work with the Windows Vista operating system and take advantage of its features and functionality.
3. How do I install a C or FORTRAN compiler on Vista?
To install a C or FORTRAN compiler on Vista, you will need to download the appropriate compiler software from a trusted source and follow the installation instructions provided. Some compilers may also come with an installation wizard that guides you through the process.
4. Are there any free C or FORTRAN compilers for Vista?
Yes, there are some free C and FORTRAN compilers available for Vista, such as GCC for C and GFortran for FORTRAN. These can be downloaded and installed from their respective websites.
5. Can I use a C or FORTRAN compiler for Vista to compile code for other operating systems?
Yes, some C and FORTRAN compilers for Vista also have the ability to cross-compile, meaning they can generate code for other operating systems such as Linux or MacOS. However, this may require additional setup and configuration.
71K
