Why Does This Program Cause a Segmentation Fault?
In summary: Here is my final code:#include<stdio.h>#include<stdlib.h>#include<string.h>void form_temp_array(char **a,char **b,int n,void (*t)(char *,char *)){ int i; for(i=0 ;i<n; i++) (*t)(b[i],a[i]);}void reverseWord(char *new_word,char *word){ strcpy(new_word,word); strrev(new_word);}int main(int argc,char *argv[]){ int i; char buffer[20]; FILE *f1,*f2; char* w[]={"PROGRAMMING","CODING"}; int n = sizeof(w)/sizeof(char**); char* a[n];
gruba
206
Write a program that reads strings(words) from a text file and copy the inverted words to another file (use the command line arguments). Form a new array of words b from original array a using the function
void formNewArray(char **a, char **b, int n, char* (*t)(char *));
where n is the number of words in array, and (*t) is the pointer to function for inverting a string.
-File handling
-Pointers
The following program gives SIGSEGV segmentation fault in function formNewArray():
Code:
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
void form_temp_array(char **a,char **b,int n,char* (*t)(char *))
  int i;
  for(i=0 ;i<n; i++)
  b[i]=(*t)(a[i]);
char* reverseWord(char *word)
  char *new_word;
  new_word=(char*)malloc(sizeof(strlen(word+1)));
  new_word=strrev(word);
  return new_word;
void print(char **arr,int n)
  int i;
  for(i=0; i<n; i++)
  printf("%s\n",arr[i]);
int main()
  char* a[]={"PROGRAMMING","CODING"};
  int n=sizeof(a)/sizeof(char**);
  char* b[n];
  printf("original words:\n");
  print(a,n);
  printf("reversed words:\n");
  form_temp_array(a,b,n,&reverseWord);
  print(b,n);
  free(reverseWord);
  return 0;
rcgldr said:
In reverseWord(), allocate memory for new word
Code:
    char *new_word = malloc(strlen(word)+1);
In form_temp_array, just assign to b:
Code:
    b[i] =(*t)(a[i]));
Code:
Code:
    b[i] =(*t)(a[i]));
Trying to edit my answer had problems so I deleted it. You can delete your prior post also if you want. The issue is in main: char *a[] points to literal strings, so they can't be reversed, as they could be in write-protected memory. Rather than allocate memory, copy, and reverse in reverseWord(), I thought it would be better to change main(), and allocate memory for each pointer in a and make copies of the literal strings. I used w[] as an array of pointers to the literal strings.
Code:
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
    int i;
    for(i=0 ;i<n; i++)
        b[i] = (*t)(a[i]);
    return strrev(word);         /* or _strrev, depending on compiler */
    int i;
    for(i=0; i<n; i++)
int main()
    int i;
    char* a[n];          /* or    char** a = _alloca(n*sizeof(char*)); */
    char* b[n];          /* or    char** b = _alloca(n*sizeof(char*)); */
    for(i = 0; i < n; i++){
        a[i] = malloc(strlen(w[i])+1);
        strcpy(a[i], w[i]);
    print(a,n);
    form_temp_array(a,b,n,reverseWord);
    print(b,n);
        free(a[i]);
    return 0;
Likes gruba
I have updated the code, and there is still an error.
Also, I don't think that you can use operator = for string manipulation.
I updated my previous answer to show working code. The issue was that a pointed to literals, so I used an array called w, then in a, I allocated memory and copied the literal strings.
Several problems, the main being:
  • char *new_word = _strrev(word);
    return new_word;
The new_word pointer is a local variable in reverseWord and is not available outside that function (it is allocated on the stack and deallocated when the function returns).
    return new_word;
It doesn't matter, since what is being returned is the pointer to the string from strrev(), not a reference to new_word. Since strrev reverses in place, there's no point in using the returned value, but since it does return the pointer to word, the code can be simplfied to:
Code:
    return new_word;
That would be a problem if the function were returning a pointer to new_word. But it is returning the value. That value will be copied somewhere so it doesn't matter that new_word is lost.
Code:
It can be simplified further by having no reverseWord at all and simply passing a pointer to strrev as an argument.
True, that would be better still. I wasn't sure if it would be OK to use a pointer to a library function for this class assignment. So in main(), it would be:
Code:
    form_temp_array(a,b,n,strrev);
Assume that file1 contains original words, and is the first argument of a command line.
How to read the content of file1 and put the inverses to file2, which is the second argument of a command line?
Thanks for all your help, I have figured out how to do file manipulation.
Related to Why Does This Program Cause a Segmentation Fault?
1. What is a pointer to function in C?
A pointer to function in C is a variable that stores the memory address of a function. It allows the programmer to pass functions as arguments to other functions, or to dynamically call different functions at runtime.
2. How do you declare a pointer to function in C?
To declare a pointer to function in C, you use the syntax: return_type (*pointer_name)(parameter_list); where return_type is the return type of the function, pointer_name is the name of the pointer, and parameter_list is the list of parameters the function takes in.
3. How do you assign a function to a pointer to function in C?
To assign a function to a pointer to function in C, you simply use the address-of operator (&) before the function name. For example: pointer_name = &function_name;
4. How do you use a pointer to function in C?
To use a pointer to function in C, you can call the function using the pointer name and passing in the necessary arguments. Alternatively, you can also use the dereference operator (*) before the pointer name to access the function and call it directly.
5. What are the advantages of using pointers to function in C?
Using pointers to function in C allows for more flexibility and dynamic behavior in the code. It also allows for passing functions as arguments, which can be useful in implementing different algorithms or callback functions. Pointers to function can also save memory space by avoiding the need to copy the function body multiple times in the code.
