C/C++ C++: Printing output based on variable value
The discussion focuses on a programming task involving the output of specific strings based on the value of an enumerated type, `GroceryItem`. Initially, the user attempted to use a while loop to determine the output, but it was pointed out that the loop's condition would prevent execution. The user then revised the code to use if and else if statements, which correctly output "Fruit" for `GR_APPLES`, "Drink" for `GR_JUICE` and `GR_WATER`, and "Unknown" for any unrecognized value. The final code successfully passed all tests, demonstrating the correct implementation of conditional logic in C++.
needOfHelpCMath
Print either "Fruit", "Drink", or "Unknown" (followed by a newline) depending on the value of userItem. Print "Unknown" (followed by a newline) if the value of userItem does not match any of the defined options. For example, if userItem is GR_APPLES, output should be:
Fruit
Code:
#include <iostream>
using namespace std;
int main() {
   enum GroceryItem {GR_APPLES, GR_BANANAS, GR_JUICE, GR_WATER};
   GroceryItem userItem = GR_APPLES;
   while ( userItem != GR_APPLES) {
         if (userItem == GR_APPLES) {
         cout << userItem << "Fruit" << endl;
   return 0;
Technology news on Phys.org
Re: i don't know if I am on right track but give me some help
You have the statement:
[m]userItem = GR_APPLES;[/m]
And then the condition on your while loop is:
[m]userItem != GR_APPLES[/m]
So, the code within the loop will never get executed. Without any means of terminating the loop, if the condition on the loop was:
[m]userItem == GR_APPLES[/m]
the loop would run endlessly. When running a while loop, you need for the condition to eventually become false, so the loop will terminate.
edit: I have edited your thread title to show the nature of the question being asked.
okay I fix it but still would not print out 'Fruit" is any other hint you can give me?
What does your amended code look like now? I will be glad to take a look and offer further suggestions. :)
well I figure out my issue that the programs did not want any while loop instead it wanted if and else if statements
Code:
#include <iostream>
int main() {
      cout << "Fruit" << endl;
    if (userItem == GR_BANANAS) {
   if(userItem == GR_JUICE) {
      cout << "Drink" << endl;
   else if (userItem == GR_WATER) {
   else if (userItem == (GroceryItem)5) {
   cout << "Unknown" << endl;
   return 0;
All tests passed
Testing with userItem = GR_APPLES
Your output: Fruit
Testing with userItem = GR_JUICE
Your output: Drink
Testing with userItem = (GroceryItem)5
Your output: Unknown
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
