BRN
- 108
- 10
Hi everybody!
I need to compute a C++ program for solve Schrodinger equation and calculate nuclear density.
My nucleus is made up of only neutrons immersed in a potential of a harmonic oscillator.
Schrodinger equation is:
$$[-\frac{\hbar^2}{2m}\triangledown^2+V_{HO}(r)]\psi=E\psi$$
with $$V_{HO}(r)=\frac{1}{2}m\omega^2r^2$$
At frist time I should use the HO eigenvalues formula
$$E_{nl}=\hbar\omega(2n+l+\frac{3}{2})$$
then, I should use a eigenvalues generator by shooting method.
Finally, my density equation is
$$n(r)=\frac{1}{4\pi r^2}\sum_\alpha(2j_\alpha+1)\psi_{\alpha}^2(r)$$
with ##\alpha## quantum number ##n_{\alpha}, l{\alpha}, j_{\alpha}##
I have some problem to do it.
1) To solve the density, I need the solver to give me back a series of eigenfunctions for each value of ##n## and ##l##. Right? But if I have the eigenvalues generated by the shooting method, I no longer have an equation that depends on ##n## and ##l##, so what can I do?
2) The shooting method:
My code:
All parameters and constant are in "parameters.h"
Schrodinger solver class are "schroddy.h"
and "schroddy.cpp"
Potential class are "initpot.h"
and "initpot.cpp"
Density class "density.h"
and "density.cpp"
I hope I posted in the right session, I have not found a specific ...
Could someone help me? thanks!
- I should provide two test eigenvalues, E1 and E2 and calculate the relative eigenfunctions.
- If they are in disagreement in ##r_{max}##, then I define ##E_t = (E1-E2) / 2##, calculate the relative eigenfunction and study the sign in ##r_{max}##.
- If it is concordant, it replaces the eigenvalue between E1 and E2.
- One proceeds for further bisections until: ##|\psi (r_{max}|<10^{-6}##
My code:
Code:
//parameters.h
#pragma once
//#ifndef parameters_h
//#define parameters_h
#include<cmath>
namespace Parameters
const int NN=10; // Neutrons number
const int NP=10; // Protons number
const double mp= 1.6726219e-27 ; // Proton mass
const double mn= 1.6749273e-27 ; // Neutron mass
const double Rn=1e-9 ;
// Spin-Orbit potential parameters
//const double k0= ;
//const double r0= ;
// HO potential parameters
const double m=mn ;
const double f = 100;
//double r= ;
// Eigenvalues generator parameters
double eigenvalue1=0.93250 ;
double eigenvalue2=1.36256 ;
double error=10e8; //maybe you mean 1e-08?
// Other parameters
const unsigned int energyLevel = 1;
const int angularMomentum = 1;
const double PI = 4*atan(1);
const double hbar = 1.0545718*1e-34;
const double x_min=0; //Integration
const double x_max=3*Rn; //Interval
//#endif
Code:
#pragma once
class InitialPot;
//hierarchy for eigenvalue objects
class Eigenvalues
public:
virtual double eigenvalue() const = 0;
virtual ~Eigenvalues();
virtual Eigenvalues* clone() const = 0;
private:
};class HarmonicEigenvalues: public Eigenvalues
public:
HarmonicEigenvalues(double omega, unsigned int n, int l);
double eigenvalue() const override;
//setEnergyLevel(unsigned int n);
//setAngularMomentum(int l);
Eigenvalues* clone() const override;
private:
HarmonicEigenvalues();
const double m_omega;
//if you want to be able to change quantum numbers within same object, implement set methods and remove const keyword
const unsigned int m_n;
const int m_l;
};class GenericEigenvalues: public Eigenvalues
public:
GenericEigenvalues (double eigval1, double eigval2, double eigenvalt, double err);
private:
GenericEigenvalues();
const double m_eigval1;
const double m_eigval2;
const double m_eigenvalt;
const double m_err;
};//Shroedinger class + solverclass Schroddy
public:
Schroddy(const InitialPot& pot, const Eigenvalues& eigenval); //if you have more parameters to pass in, change this
double solveShroddyByRK(double x0, double x1, double psi0, double psiPrime0, unsigned long NSteps) const; //psiPrime0 is boundary condition on first derivative of eigenfunction
~Schroddy();
private:
const InitialPot* const m_pot;
const Eigenvalues* const m_eigenval;
Code:
//Class for Schrodinger equation solver
# include <math.h>
# include <stdlib.h>
# include <stdio.h>
# include "initpot.h"
# include "parameters.h"
# include "schroddy.h"
# include <cmath>
# include <vector>Eigenvalues::~Eigenvalues() {}
* HO Eigenvalues generator
HarmonicEigenvalues::HarmonicEigenvalues(double omega, unsigned int n, int l): m_omega(omega), m_n(n), m_l(l) {}
double HarmonicEigenvalues::eigenvalue() const
return Parameters::hbar*m_omega*(2*m_n+m_l+(3/2));
Eigenvalues* HarmonicEigenvalues::clone() const
return new HarmonicEigenvalues(*this);
* Eigenvalues generator by shooting method
GenericEigenvalues::GenericEigenvalues (double eigval1, double eigval2, double eigenvalt, double err): m_eigval1(eigval1), m_eigval2(eigval2), m_eigenvalt(eigenvalt), m_err(err){}
double GenericEigenvalues::eigenvalue() const //this must return a double..
//m_eigval1=Parameters::eigenvalue1; //cannot assign to a const variable; don't you pass in these values to the constructor? why do it twice?
//m_eigval2=Parameters::eigenvalue2;
//m_err=Parameters::error;return 0.0;
Eigenvalues* GenericEigenvalues::clone() const
return new GenericEigenvalues(*this);
* Schrodinger equation solver by Runge-Kutta method
Schroddy::Schroddy(const InitialPot& pot, const Eigenvalues& eigenval): m_pot(pot.clone()), m_eigenval(eigenval.clone()) {}
Schroddy::~Schroddy()
delete m_pot;
delete m_eigenval;
double Schroddy::solveShroddyByRK(double x0, double x1, double psi0, double psiPrime0, unsigned long NSteps) const
//implement runge-kutta here..
const double h = (x1 - x0)/NSteps;
const double factor = 2*Parameters::mn/(Parameters::hbar*Parameters::hbar);
const double eigenvalue = m_eigenval -> eigenvalue();
double runningX = x0, runningPsi = psi0, runningPsiPrime = psiPrime0;
std::vector<double> psiArray;
psiArray.push_back(psi0);
for (unsigned long i = 0; i < NSteps; ++i)
//compute decoupled RK factors
const double k1 = runningPsiPrime;
const double l1 = (m_pot -> potential(runningX) - eigenvalue)*runningPsi;
const double k2 = runningPsiPrime + h/2*l1;
const double l2 = (m_pot -> potential(runningX + h/2) - eigenvalue)*(runningPsi + h/2*k1);
const double k3 = runningPsiPrime + h/2*l2;
const double l3 = (m_pot -> potential(runningX + h/2) - eigenvalue)*(runningPsi + h/2*k2);
const double k4 = runningPsiPrime + h*l3;
const double l4 = (m_pot -> potential(runningX + h) - eigenvalue)*(runningPsi + h*k3);
//advance running variables and store intermediate results
runningPsi += h/6*factor*(k1 + 2*k2 + 2*k3 + k4);
runningPsiPrime =+ h/6*factor*(l1 + 2*l2 + 2*l3 + l4);
runningX += h;
psiArray.push_back(runningPsi);
//work out normalizatiion constant
double psiSquared = 0, normalPsi=0;
for (std::vector<double>::iterator it = psiArray.begin(); it != psiArray.end(); ++it)
psiSquared += (*it)*(*it); //derefence iterator at array's element and square (brackets are needed!)
const double scalar = psiSquared*h;
//return normalized eigenfunction (on interval [x0, x1]) and job done!
return normalPsi=runningPsi/sqrt(scalar);
Code:
#pragma once
class InitialPot //pure virtual base class
public:
virtual double potential(double x) const = 0;
virtual ~InitialPot();
virtual InitialPot* clone() const = 0; //virtual constructor
private:
class HOPot: public InitialPot //derived class
public:
// HO potential
HOPot(double m, double omega);
double potential(double x) const override;
//double getOmega() const;
InitialPot* clone() const override;
private:
HOPot(); //same as before
const double m_m, m_omega;
and "initpot.cpp"
Code:
//Class for initial potentials
#include <cmath>
#include "initpot.h"
InitialPot::~InitialPot() {}HOPot::HOPot(double m, double omega): m_m(m), m_omega(omega) {}
double HOPot::potential(double x) const
double hopot=(1/2)*m_m*(m_omega*m_omega)*(x*x);
return hopot;
InitialPot* HOPot::clone() const
return new HOPot(*this); //return a derived class object through a base class pointer
Code:
#pragma once
class Densities
public:
virtual double density() const = 0;
virtual ~Densities();
virtual Densities* clone() const = 0;
private:
};class Theoreticaldensity: public Densities
public:
Theoreticaldensity(double eigenfunc, double x);
double density() const override;
Densities* clone() const override;
private:
Theoreticaldensity();
const double m_x;
double m_eigenfunc;
Code:
# include "density.h"
# include <cmath>/*============================================
* Theoretical density
Densities::~Densities() {}
Theoreticaldensity::Theoreticaldensity(double eigenfunc, double x): m_eigenfunc(eigenfunc), m_x(x) {}
double Theoreticaldensity::density() const
//m_eigenfunc& schroddy::normalPsi;
return (1/(4*Parameters::PI*(m_x*m_x)))*Parameters::NN*(m_eigenfunc*m_eigenfunc);
Densities* Theoreticaldensity::clone() const
return new Theoreticaldensity(*this);
