C: Stack with binary search trees
In summary: So, why bother?In summary, the conversation is about creating a linear stack with N binary search trees and printing the content of the stack. The code provided has some errors, specifically with the printing loop. Suggestions have been made to fix the errors, but there has been no response from the poster.
gruba
206
Create a linear stack with N binary search trees (data of a tree node is an integer). Read N trees, push them on the stack. Then, empty the stack and store trees in the new array and print the content of the stack.
2. The attempt at a solution
The following code gives unexpected output (stack content is not printed correctly - look at the printing stack loop at the line [itex]\sim[/itex] 215):
Code:
#include<stdio.h>
#include<stdlib.h>
#define N 2
typedef struct
    int num;
}TREE_INFO;
typedef struct tree_node
    TREE_INFO treeInfo;
    struct tree_node *left,*right;
}TREE_NODE;
typedef struct stack
    TREE_NODE arr[N];
    int tos;
}STACK;
int isFull(STACK *s)
    return s->tos == N-1;
int isEmpty(STACK *s)
    return s->tos ==-1;
int push(STACK *s,TREE_NODE *stackInfo)
  if(isFull(s))
  return0;
  s->arr[++s->tos]=*stackInfo;
  return1;
int pop(STACK *s,TREE_NODE *stackInfo)
  if(isEmpty(s))
     return0;
  *stackInfo=s->arr[s->tos--];
  return1;
TREE_NODE* emptyTheStack(STACK *s)
   if(isEmpty(s))
        return0;
   int i=0;
   TREE_NODE *arr=(TREE_NODE*)malloc(((s->tos+1)*sizeof(TREE_NODE))*N *1000);
   while(!isEmpty(s))
    arr[i++]=s->arr[s->tos--];
   return arr;
void readTree(TREE_INFO *treeInfo)
  do
      printf("Enter positive integer: ");
      scanf("%d",&treeInfo->num);
  while(treeInfo->num <0);
TREE_NODE* searchTree(TREE_NODE *root,int num)
    if(root ==0)
        return0;
    elseif(num == root->treeInfo.num)
        return root;
    elseif(num <= root->treeInfo.num)
        return searchTree(root->left,num);
    elsereturn searchTree(root->right,num);
TREE_NODE* formNode(TREE_INFO *treeInfo)
    TREE_NODE*newNode=(TREE_NODE*)malloc(sizeof(TREE_NODE));
    newNode->left=newNode->right=0;
    newNode->treeInfo=*treeInfo;
    return newNode;
TREE_NODE* addNodeTree(TREE_NODE *root,TREE_INFO *treeInfo)
    if(root ==0)
        return formNode(treeInfo);
    if(treeInfo->num <= root->treeInfo.num)
         root->left=addNodeTree(root->left,treeInfo);
    else root->right=addNodeTree(root->right,treeInfo);
    return root;
void deleteTree(TREE_NODE *root)
   if(root !=0)
      deleteTree(root->left);
      deleteTree(root->right);
      free(root);
void printTreeInorder(TREE_NODE *root)
   if(root !=0)
      printTreeInorder(root->left);
      printf("%d ",root->treeInfo.num);
      printTreeInorder(root->right);
int main()
    int i;
    TREE_INFO treeInfo;
    char option;
    TREE_NODE *srch,*root,*arr;
    STACK st;
    st.tos=-1;
    i=1;
    root=0;
    printf("Adding N trees on the stack: \n");
    while(i<=N)
        do
           fflush(stdin);
           printf("\nEnter option: ");
           scanf("%c",&option);
           if(option =='A')
              fflush(stdin);
              printf("Enter data about %d. tree: \n",i);
              readTree(&treeInfo);
              srch=searchTree(root,treeInfo.num);
              if(srch)
                srch->treeInfo=treeInfo;
              else
                root=addNodeTree(root,&treeInfo);
            elseif(option =='P')
                printf("Data about %d. tree: \n",i);
                printTreeInorder(root);
           elseif(option !='0')
                printf("Unknown option.\n");
        while(option !='0');
       if(push(&st,root))
            printf("%d. tree is pushed on the stack.\n",i);
        if(isFull(&st))
            printf("Stack is full.\n");
        root=0;
        srch=0;
        i++;
    arr=emptyTheStack(&st);
    i=1;
    printf("Printing stack: \n");
    while(i<=N)
        printTreeInorder(arr);
        i++;
    if(isEmpty(&st))
        printf("Stack is empty.\n");
    free(arr);
    return0;
Example program:
Code:
Enter option: A
Add node to 1. tree:10
Enter option: A
Add node to 1. tree:8
Enter option: A
Enter option: P //print a tree
Data about 1. tree:8 10//note: inorder traversal without duplicate values
Enter option:0
1. tree is pushed on the stack.
Enter option: A
Add node to 2. tree:6
Enter option: A
Add node to 2. tree:9
Enter option: P
Data about 2. tree:6 9
Enter option:0
2. tree is pushed on the stack.
Stack is full.
Print stack:
6 9
8 10
For the same input, I am getting the following output:
Code:
Print stack:
6 9
6 9
This means that the last input tree is printed N times.
Could someone point out how to resolve this error?
Thanks for replies.
No one else has posted in this thread all day. I can't speak for the others, but for myself, I don't feel like responding. Too often, others and I have made suggestions on how you could fix your code, but with no response from you, either that the reponse was helpful or that it was way out in left field.
Related to C: Stack with binary search trees
1. What is a stack with binary search trees?
A stack with binary search trees is a data structure that combines the functionality of a stack and a binary search tree. This means that elements can be added or removed from the stack in a last-in-first-out (LIFO) manner, while also maintaining the efficient searching and sorting capabilities of a binary search tree.
2. How does a stack with binary search trees work?
A stack with binary search trees works by storing elements in a hierarchical structure where each element has at most two child nodes. The top of the stack is always the root of the tree, and elements are added or removed by following the rules of a binary search tree - smaller elements are placed to the left and larger elements to the right.
3. What are the advantages of using a stack with binary search trees?
One advantage of using a stack with binary search trees is that it allows for efficient searching and sorting of elements, as the binary search tree has a time complexity of O(log n) for these operations. Additionally, the LIFO structure of the stack allows for quick and easy access to the most recently added element.
4. What are some common use cases for a stack with binary search trees?
A stack with binary search trees is commonly used in applications where both efficient searching and LIFO functionality are needed. This includes tasks such as implementing undo/redo functionality, managing browser history, and evaluating mathematical expressions.
5. Can a stack with binary search trees be implemented in any programming language?
Yes, a stack with binary search trees can be implemented in any programming language that supports the creation of binary search trees and has the ability to manipulate stack data structures. Some common languages that can be used for this purpose include Java, C++, and Python.
9K
