C: Store The Content Of Linked List Into BST
In summary, the program is trying to create a singly circular linked list with n arbitrary stored positive integer numbers, then create a BST with all prime numbers from the list and store them in a text file in descending order. However, there are several errors in the code, such as passing incompatible pointer types and trying to store values in an uninitialized pointer. Additionally, the tree node should only have an int info member instead of a NODE plist member.
gruba
206
The following program should create singly circular linked list
which has n arbitrary stored positive integer numbers.
Then, create BST which has all primes from the list,
and store them in text file in descending order.
Linked list
Binary search tree
File handling
Mod note: Indented code and added "=c" to code tag.
C:
#include <stdio.h>
#include <stdlib.h>
typedef struct list_node
   int info;
   struct list_node *next;
} NODE;
typedef struct tree_node
   NODE plist;
   struct tree_node *left,*right;
}TREE_NODE;
void read(NODE *plist)
   printf("Positive integer: ");
   scanf("%d", &plist->info);
void insert_list_node(NODE *n_ptr,int info)
   NODE *start=n_ptr;
   while(n_ptr->next != start)
      n_ptr=n_ptr->next;
   n_ptr->next=(NODE*)malloc(sizeof(NODE));
   n_ptr=n_ptr->next;
   n_ptr->info=info;
   n_ptr->next=start;
int prime(int x)
   int div;
   int num_of_div=2;
   for(div=0;div<x/2;div++)
      if(x % div == 0)
      num_of_div++;
   if(num_of_div == 2)
      return 1;
   return 0;
TREE_NODE *form_node(NODE *plist)
   TREE_NODE *new_node=(TREE_NODE*)malloc(sizeof(TREE_NODE));
   new_node->left=new_node->right=0;
   new_node->plist=*plist;
   return new_node;
TREE_NODE *add_to_tree(NODE *plist,TREE_NODE *root,int (*prime_ptr)(int))
   if(root == 0)
      return form_node(plist);
   if((plist->info <= root->plist.info) && ((*prime_ptr)(plist->info) == 1))
      root->left=add_to_tree(plist,root->left,prime);
      insert_list_node(plist,plist->info);
   else if((plist->info > root->plist.info) && ((*prime_ptr)(plist->info) == 1))
      root->right=add_to_tree(plist,root->right,prime);
   return root;
void print_tree_to_file(TREE_NODE *root,FILE *fptr)//reversed inorder traversion
   if(root != 0)
      print_tree_to_file(root->right,fptr);
      fprintf(fptr,"%d\n",root->plist.info);
      print_tree_to_file(root->left,fptr);
int main()
   TREE_NODE *root=0;
   NODE *plist;
   /*FILE *fptr="file.txt";*/
   int n,i;
   do
      printf("n=");
      scanf("%d",&n);
   while(n<1);
   for(i=1;i<=n;i++)
      read(&plist);
      root=add_to_tree(&plist,root,&prime);
   /*print_tree_to_file(root,fptr);*/
   return 0;
Segmentation faults:
|96|warning: passing argument 1 of 'read' from incompatible pointer type [enabled by default]|
|16|note: expected 'struct NODE *' but argument is of type 'struct NODE **'|
|97|warning: passing argument 1 of 'add_to_tree' from incompatible pointer type [enabled by default]|
|55|note: expected 'struct NODE *' but argument is of type 'struct NODE **'|
Linked list
Binary search tree
File handling
C:
#include <stdio.h>
#include <stdlib.h>
   int info;
} NODE;
   NODE plist;
}TREE_NODE;
   NODE *start=n_ptr;
      n_ptr=n_ptr->next;
   n_ptr=n_ptr->next;
   n_ptr->info=info;
   n_ptr->next=start;
int prime(int x)
   int div;
   int num_of_div=2;
      if(x % div == 0)
      num_of_div++;
   if(num_of_div == 2)
      return 1;
   return 0;
   return new_node;
   if(root == 0)
   return root;
   if(root != 0)
int main()
   TREE_NODE *root=0;
   NODE *plist;
   int n,i;
   do
      printf("n=");
      scanf("%d",&n);
   while(n<1);
   for(i=1;i<=n;i++)
      read(&plist);
   return 0;
There are a number of things wrong with your code, starting with the errors shown above.
In main(), the two lines in the for loop show &plist, but plist is already a pointer, so & is not needed. A more serious problem is that you are attempted to store values in plist -> info (in your read() function), but you haven't allocated any memory to hold what plist is supposed to point to. That is what is giving you the segmentation faults.
The declaration NODE * plist that you have in main() merely allocates memory on the stack for a pointer (to a NODE struct), but that pointer is uninitialized, meaning that it isn't pointing to a location that is safe for you to store something in. For each NODE struct that you use, you need to allocate memory from the heap, using malloc() or other memory allocation function.
Tree node should not need a NODE plist member, just an int info member, since a tree node will not be using the next pointer. Are the nodes in the circular list with prime numbers to be removed from the list, or left in the list as the BST is created?
Somewhat faster prime function:
Code:
// largest prime        < 2^??  largest prime square root
//           2147483647 < 2^31       45337
//           4294967291 < 2^32       65521
//  9223372036854775783 < 2^63  3037000493
// 18446744073709551557 < 2^64  4294967291
int prime(int n)
int d;
    if(n <= 2)
        return 1;
    if((n & 1) == 0)
        return 0;
    for(d = 3; d <= 46337 && d * d <= n; d += 2){
        if((n % d) == 0)
            return 0;
    return 1;
Related to C: Store The Content Of Linked List Into BST
1. How do I store the content of a linked list into a binary search tree?
To store the content of a linked list into a binary search tree, you will need to traverse the linked list and insert each node's data into the BST. This can be done recursively or iteratively, depending on your preference. As you insert each element into the BST, make sure to maintain the proper ordering of the tree to ensure it remains a valid BST.
2. What is the time complexity of storing a linked list into a binary search tree?
The time complexity of storing a linked list into a binary search tree is O(n*log(n)), where n is the number of elements in the linked list. This is because you will need to traverse the entire linked list (O(n)) and each insertion into the BST takes O(log(n)) time.
3. Can I store a circular linked list into a binary search tree?
Yes, it is possible to store a circular linked list into a binary search tree. However, you will need to break the circularity by making the last node point to null instead of the first node. Otherwise, you may end up with an infinite loop while traversing the tree.
4. What are the advantages of storing a linked list into a binary search tree?
Storing a linked list into a binary search tree allows for efficient searching and sorting of the data in the linked list. This can be particularly useful if the linked list is already sorted or if you need to frequently search for specific elements in the list. Additionally, the BST can also be used to perform other operations such as finding the minimum or maximum element in the list.
5. Can I store duplicate elements from a linked list into a binary search tree?
Yes, it is possible to store duplicate elements from a linked list into a binary search tree. However, depending on the implementation of the BST, the duplicates may either be stored as separate nodes or merged into a single node with a count of the number of duplicates. It is important to consider how duplicates will be handled when designing a BST to store a linked list.
9K
