MHB C String Comparison: Debugging Error - "Hello" Output
  • Thread starter Thread starter ksepe
    Comparison String
The discussion centers on a coding error in a C program where the output is incorrectly producing "Hello" instead of "Goodbye" when the input "Quit" is entered. The issue arises from the use of the `strcpy` function in the conditional statement, which does not compare strings but rather copies them. Instead, the correct function to use for comparing strings is `strcmp`, which returns 0 when the two strings are identical. The corrected code snippet provided uses `strcmp` to properly check if `userString` matches "Quit", ensuring that "Goodbye" is printed when the input is correct. Additionally, it is noted that `strcpy` returns a pointer to the destination string, which is not suitable for comparison purposes.
ksepe
I am trying to compare a computer generated word to display the following however, when Quit is entered it produces the output "Hello". What is my error in the code?
Code:
#include <stdio.h>
#include <string.h>
int main(void) {
   char userString[50];
   strcpy(userString, "Quit");
   /* Your solution goes here  */
if (strcpy(userString,"Quit")==0){
   printf("Goodbye\n");
else {
   printf("Hello\n");
   return 0;
Technology news on Phys.org
On an ANSI-compliant system, strcmp(const char *str1, const char *str2) returns 0 if the strings str1 and str2 are identical.
Try
Code:
#include <stdio.h>
#include <string.h>
int main(void) {
		if (strcmp(userString, "Quit") == 0){
		else {
			printf("Hello\n");
		return 0;
The function strcpy(char *destination, char *source) returns a pointer to the destination string: a non-zero value.
*Note: you may post formatted source code by enclosing the source code in [code]...[/code] tags.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
