MHB C ++ typing censored for 'darn'
  • Thread starter Thread starter adrumheiser
The discussion revolves around a C++ coding issue where the user struggles to correctly censor the word "darn" in a string input. The original code incorrectly uses the `find` method, leading to unintended behavior where "Censored" is printed even when "darn" is not present. The key point of the solution is to check if the result of `userInput.find("darn")` is not equal to `string::npos` (which indicates that the substring was not found). The corrected condition should be `if (userInput.find("darn") != string::npos)`, ensuring that "Censored" is only printed when "darn" is actually in the input. The user confirms that this modification resolves the issue.
adrumheiser
Hi all, I am new to c++ and need help with my homework. I have tried many times and somehow cannot get it right. My following code works for 'darn' but when tested with "Dang, that was scary!," prints censored also. Any hints?
Print "Censored" if userInput contains the word "darn", else print userInput. End with newline.
#include <iostream>
#include <string>
using namespace std;
int main() {
string userInput;
userInput = "That darn cat.";
if (userInput.find("darn")) {
cout << "Censored" << endl;
else {
cout << userInput << endl;
return 0;
Technology news on Phys.org
Hi,
Your problem is in the statement (BTW use the code tag to make your code readable):
Code:
else {
As in all of C++, if the expression userInput.find("darn") has a non-zero value, the if statement is deemed to be true. Now the return value of string's find method is the position (index) of the first occurrence of parameter target in case target is actually a substring; this can range from 0 to the length of the string-1. If target is not a substring, the return value is string::npos. This last value is actually -1, which is non-zero. So in your construct userInput.find("darn") is always true unless "darn" is the first few characters of userInput. This is definitely not what you want. So modify your if statement with
Code:
if (userInput.find("darn") != -1) {
else {
It worked, thank you!
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
34K
