C/C++ C++: Using a for loop to print a countdown
  • Thread starter Thread starter needOfHelpCMath
    Loop
The discussion centers around writing a C++ program that prints a countdown from a user-defined number to one, followed by "Blastoff!". The initial code provided incorrectly resets the value of `userNum` within the for loop, leading to incorrect outputs. The corrected code uses a separate variable, `i`, initialized to `userNum`, which decrements until it reaches zero, ensuring the correct countdown is printed. The output format is confirmed to be correct, with each number and "Blastoff!" printed on a new line. Additionally, the thread was edited for clarity and readability.
needOfHelpCMath
Write code that prints: userNum ... 2 1 Blastoff! Your code should contain a for loop. Print a newline after each number and after Blastoff!. Ex: userNum = 3 outputs:
Blastoff!
Code:
#include <iostream>
using namespace std;
int main() {
   int userNum = 0;
   int i = 0;
   userNum = 3;
   i = 1;
   for (userNum = 3; 1 <= userNum; --userNum) {
   cout << userNum << endl;
 cout << "Blastoff!" << endl;
   return 0;
Run
Testing with userNum = 3.
Your output: 3
Blastoff!
✖ Testing with userNum = 1.
Expected output: 1
Blastoff!
Your output: 3
Blastoff!
Technology news on Phys.org
Re: So close what is wrong with my program
You are resetting the value of [m]userNum[/m] when you begin the for loop. This is how I would write the program:
Code:
#include <iostream>
int main()
	int userNum = 3;
	int i;
	for (i = userNum; i > 0; i--)
		cout << i << endl;
	return 0;
Please note that I have edited your thread title to describe the nature of the question being asked, and enclosed your code in the [CODE][/CODE] tags so that whitespaces are preserved and the indentation will enhance readability. :)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
