MHB -c03 write prime factorization of the LCM of A and B
The discussion focuses on calculating the least common multiple (LCM) of two numbers, A and B, using their prime factorizations. A is given as 2·3²·5·7³·11³·13², while B is 3²·5·7²·11². The LCM is determined to be 2·3²·5·7³·11³·13², which incorporates the highest powers of each prime factor from both A and B. The greatest common factor (GCF) is identified as 3²·5·7²·11², highlighting the relationship between A and B. The LCM is not simply the product of A and B unless they are relatively prime.
karush
MHB
Build the least common multiple of A and B
a. write the prime factorization of the least common multiple of A and B.
$A=2\cdot 3^2\cdot 5\cdot 7^3\cdot 11^3\cdot 13^2$
$B= 3^2 \cdot 5 \cdot 7^2 \cdot 11^2$
$\dfrac{2\cdot \cancel{3^2}\cdot \cancel{5\cdot 7^2} 7\cdot \cancel{11^2} 11\cdot 13^2}
{\cancel{3^2} \cdot 5 \cancel{\cdot 7^2} \cdot \cancel{11^2}}
=2\cdot 7\cdot 11\cdot 13^2=26026$
not sure if I went the right direction on this how do we get the prime factorization
Mathematics news on Phys.org
The LCM would be …
$2 \cdot 3^2 \cdot 5 \cdot 7^3 \cdot 11^3 \cdot 13^2$
The GCF would be …
$3^2 \cdot 5 \cdot 7^2 \cdot 11^2$
so its not A and B together? altho B is subset of A
LCM is A times B (together) only if A and B are relatively prime
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
